Hello Geoff and christian
i changed the port but am stil getting this errors: (they are on black not on red on my log console, normally eclipse shows error in red) plz help :
06 mai 14:56:07 WARN [geoserver.logging] - Could not find configuration file for logging
06 mai 14:56:21 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
06 mai 14:56:24 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\Users\OUK\Documents\GitHub\geoserver\src\web\app\src\main\webapp\data
06 mai 14:56:26 INFO [org.geoserver] - Loaded style ‘line’
06 mai 14:56:26 INFO [org.geoserver] - Loaded style ‘point’
06 mai 14:56:26 INFO [org.geoserver] - Loaded style ‘polygon’
06 mai 14:56:26 INFO [org.geoserver] - Loaded style ‘raster’
06 mai 14:56:26 WARN [org.geoserver] - No ‘workspaces’ directory found, unable to load any stores.
06 mai 14:56:30 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
06 mai 14:56:30 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [file:/C:/Users/OUK/Documents/GitHub/geoserver/src/gwc/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘gwcTLDispatcher’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [file:/C:/Users/OUK/Documents/GitHub/geoserver/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.geoserver.web.Start.main(Start.java:116)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [file:/C:/Users/OUK/Documents/GitHub/geoserver/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
… 28 more
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:135)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:54)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:394)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
… 36 more
Caused by: java.lang.NullPointerException
at org.geoserver.config.GeoServerLoader.readConfiguration(GeoServerLoader.java:620)
at org.geoserver.config.DefaultGeoServerLoader.loadGeoServer(DefaultGeoServerLoader.java:68)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:129)
… 40 more
06 mai 14:56:30 ERROR [mortbay.log] - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,src/main/webapp}
… 28 more
… 36 more
… 40 more
06 mai 14:56:30 ERROR [mortbay.log] - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL [file:/C:/Users/OUK/Documents/GitHub/geoserver/src/gwc/target/classes/applicationContext.xml]: Cannot resolve reference to bean ‘gwcTLDispatcher’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL [file:/C:/Users/OUK/Documents/GitHub/geoserver/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullPointerException:
Asma OUQALLI
Élève ingénieur : 3ème Sciences d’Information Géographique (SIG).
Chef de commission développement professionnel - Rotaract EHTP.
Chef de cellule Media - Olympiades EHTP 2012.
Ecole Hassania des Travaux Publics.
Mobile : +212 672 48 23 15.
Email : asma.ouqalli@anonymised.com..
I am not sure, but I think you use an old Geoserver data directory. I looks like you checked out out from github, try to use
C:\Users\OUK\Documents\GitHub\geoserver\data\release
For testing I would make a copy of the above directory and use the copy.
Christian
2013/5/6 Asma ouqalli <asma.ouqalli@anonymised.com>
… 28 more
… 36 more
… 40 more
… 28 more
… 36 more
… 40 more
Asma OUQALLI
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
thnks cristian, yes i download it fro git command line, i thought it’s a new release. :s can i replace it with a new stable version without trouble and error of upgrading ??
2013/5/6 Christian Mueller <christian.mueller@anonymised.com>
Christian
Asma OUQALLI
Email : asma.ouqalli@anonymised.com…
… 28 more
… 36 more
… 40 more
… 28 more
… 36 more
… 40 more
Asma OUQALLI
Hi
Downloading from github is intended for developers. Please download and install from here
http://geoserver.org/display/GEOS/Stable
This should fix your problems.
Christian
Christian
Asma OUQALLI
… 28 more
… 36 more
… 40 more
… 28 more
… 36 more
… 40 more
Asma OUQALLI
