[Geoserver-devel] Exposing the ability to reload a feature type in the REST API
currently if someone needs to reload a specific feature type definition/structure they can only do so from the UI,
but not from the REST API. A use case here is something changing the structure of the feature type in the storage,
and the consequent need to inform GeoServer about it.
The REST API only offers a full resource pool reset, and even with the “reload feature type” button in the UI, we
are looking at a somewhat blunt instrument, in that it’s actually removing from the resource pool (and thus disposing)
the entire store attached to it:
https://github.com/geoserver/geoserver/blob/master/src/web/core/src/main/java/org/geoserver/web/data/resource/FeatureResourceConfigurationPanel.java#L132
This in turn might affect all in flight operations attached to the store.
How about we change that a little, so that:
  • The store cleaning, if necessary, is done inside ResourcePool.clear(featureType)
  • The cleaning is done in an intelligent way, and if the store is a ContentDataStore, we only call store.getEntry(name).dispose()?
    (btw, can anyone confirm that is not going to cause issues? any better way to clear the feature type to force the store to re-compute it?)
    And then, have FeatureTypeResource also leverage that code.
In terms of REST API change, I was thinking to mimic the existing reset endpoint, and perform resetting on a feature type if a empty POST is done against the resource, along with a ?reset=true parameter (missing a more significant HTTP method to do so), e.g.:
http://host/geoserver/rest/workspaces/topp/datastores/states_shapefile/featuretypes/states?reset=true
A possible alternative would be to build inside the existing reset path instead, something like a empty POST to:
http://host/geoserver/rest/reset/workspaces/topp/datastores/states_shapefile/featuretypes/states
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
This seems the more elegant option to me. Perhaps "?reload=true" as reset might imply undoing some change? You wrote "reload" in the title and that seemed clear to me.
I wonder if this new functionality has any implications for app-schema with its cooperating data stores and static data store registry?
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
I had a JIRA issue on this a while back; when we were looking at how to let GeoServer know what to do when a new column was added to a postgis table.
We ended up with a recommendation for something similar to recalculate, but with different options, including one that would regenerate the cache of attributes like the GUI (but funding never came through).
There is a better way, ContentDataStore has an method to clear is ContentEntry (which caches the schema at the DataStore level).
On 4 November 2016 at 03:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today. http://sdm.link/xeonphi
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
On Sat, Nov 5, 2016 at 11:58 PM, Ben Caradoc-Davies <ben@anonymised.com>
seemed clear to me.
Good point.
Hum... are app-schema delegate stores even exposed in the REST API? I
thought it was managing them internally, without exposing
them to GeoServer?
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Nov 7, 2016 at 7:58 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
table.
- https://osgeo-org.atlassian.net/browse/GEOS-6621
- https://osgeo-org.atlassian.net/browse/GEOS-6636 (sorry the table is
wrecked here)
Yep, thank you, that indeed looks like a better way.... I am tempted to
implement like this:
store.getEntry(typeName).getState(Transaction.AUTO_COMMIT).flush()
in order to leave be eventual ongoing transactions (otherwise we'd probably
be breaking their accounting/reporting), which are going to die soon
anyways.
Ing. Andrea Aime
@geowolf
Technical Lead
them to GeoServer?
Yes, the delegates are managed internally. I was thinking more of whether there will be any need for an app-schema data store to be reloaded. I cannot think of a use-case. Any mapping changes should be a full REST update and not just a reload.
Kind regards,
Director
New Zealand
