There are several tests in the community DDS/BIL module that are failing. There was some discussion on this issue attached to a pull request (https://github.com/geoserver/geoserver/pull/616), but no resolution.
I've looked at the BIL output produced in the tests, and it appears to be correct. I believe that the module is working correctly, and that the test is incorrect. The tests are a bit odd in that they only test the number of bytes returned, not the content of the response.
I'm willing to put a little time toward sorting this out. Is there a maintainer for this module who might be able to provide more info?
resolution.
I’ve looked at the BIL output produced in the tests, and it appears to
I’m willing to put a little time toward sorting this out. Is there a
Looks like the original author was Tisham Dhar, and I assume he's the closest thing to the maintainer. He's pretty active in the World Wind, and I can probably get in touch with him there.
Parker
On 9/12/14, 3:22 PM, Jody Garnett wrote:
Thanks Parker: Since this is a community module it may be random to find the module maintainer. Check the pom.xml for details?
Jody Garnett
On Fri, Sep 12, 2014 at 2:29 PM, Parker Abercrombie <parker.abercrombie@anonymised.com <mailto:parker.abercrombie@anonymised.com>> wrote:
resolution.
that the
