[Geoserver-devel] Feature Info
I am new to Geoserver so please be gentle!
I have created a thin client to view some layers from Geoserver. I attach
the html below which shows my coding for this. You may not be able to view
the layers as the servers are internal.
I want to be able to click on features within all layers and for the
attribution to be displayed for each feature when I click on it. Ideally, I
would like to be able to click on a point in a layer and a baloon pops up
with all (or some) attribition associated with that feature.
Would be grateful if someone could have a look at the attached code and add
a section of code to reflect what I require above. This would greatly help
me!
Thanks.
Nick
<html xmlns="http://www.w3.org/1999/xhtml&quot;&gt;
    <head>
        <title>Nick's Experiment with Geoserver</title>
        <link rel="stylesheet"
href="http://openlayers.org/dev/theme/default/style.css&quot; type="text/css" />
        <link rel="stylesheet" href="style.css" type="text/css" />
        <!--set up size of map on screen-100% of width, 400 pixels in
height-->
        <style type="text/css">
            #controls
                width: 100%;
                height: 700px;
        </style>
       <!--Get Open Layers JavaScript library-->
       <script src="http://openlayers.org/dev/OpenLayers.js&quot;
type='text/javascript'></script>
        <script type="text/javascript">
            <!--When loading tiles from 3rd party, good to have re-tries for
tiles not delivered on first request-->
            OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
            OpenLayers.Util.onImageLoadErrorColor = "transparent";
            <!--Creates variable that will be the map object-->
            var map;
            <!--Creates variables to designate initial view of map-->
            var lon = -180;
            var lat = -180;
            var zoom = 2;
            <!--Initial function that fires when page is loaded-->
            function init(){
                <!--create OpenLayers map object-->
                map = new OpenLayers.Map( 'map' );
                <!--SET UP BASEMAP LAYERS-->
                    <!--State Outlines from the BLM-->
                    var blm_states = new OpenLayers.Layer.WMS("ARCS",
                        " http://211.55.30.20/System.wms&quot;,
                        {layers: "ARCS", reaspect: "false",transparent:
"true"}, {isBaseLayer: true, singleTile: true, ratio: 1, visibility:true});
                    <!--***NOTE the 'singleTile' parameter: layers with
labels will often have distracting-->
                    <!-- duplicate labeling when streamed normally as
tiles-->
                    <!--USGS Topos-->
                    var worldmap = new OpenLayers.Layer.WMS( "Global Image",
                        "http://211.55.30.20/System.wms&quot;,
                        {layers: "Bathymetry", reaspect:
"false"},{singleTile: false, ratio: 1, isBaseLayer: true});
                    var Vector = new OpenLayers.Layer.WMS( "Vector Base",
                        {layers: "Vector", reaspect: "false"},{singleTile:
                <!--SET UP OVERLAY LAYERS-->
                    var blm_lease = new OpenLayers.Layer.WMS("British
point",
                        "http://62.172.108.29/geoserver/wms&quot;,
                        {layers: "geoserver_layer", reaspect: "false",
transparent: "true"},{isBaseLayer: false,visibility:false});
                    <!--***NOTE the 'reaspect' parameter set to false for
BLM layers. For WMS services emanating from ArcIMS,-->
                    <!-- this parameter often needs to be included for
layers to overlay correctly in non-ESRI viewers-->
                    var sale_lease = new OpenLayers.Layer.WMS("British point
2",
                        "http://20.180.555.29/geoserver/wms&quot;,
                        {layers: "geoserver2_layer", reaspect: "false",
transparent: "true"}, {isBaseLayer: false, visibility:false});
                    var blm_land = new OpenLayers.Layer.WMS("British point
3",
                        {layers: "geoserver3_layer", reaspect:
"false",transparent: "true"}, {isBaseLayer: false, visibility:false});
                    <!--***NOTE we are requesting multiple layers from the
same WMS service. For large datasets, there will often be-->
                    <!-- an 'overview' layer at zoomed-out scales with a
more detailed layer closer in so as to improve performance-->
                    var nf_land = new OpenLayers.Layer.WMS("National
Forests",
"http://www.geocommunicator.gov:80/wmsconnector/com.esri.wms.Esrimap/BLM_MAP_SURFACE_MGT_AGY&quot;,
                        {layers: "National Forest Labels,National Forests
Dissolved,National Forests", reaspect: "false",transparent: "true"},
{isBaseLayer: false, singleTile: true, ratio: 1, visibility:false});
tiles-->
                    <!--Pulling a Census Block Group layer from the new
DRCOG WMS Service-->
                    var drcog_blk = new OpenLayers.Layer.WMS("DRCOG Census
Blk Grps",
                        "http://gis.drcog.org/geoserver/wms?&quot;,
                        {layers: "bg2000", transparent: "true"},
{visibility:false, isBaseLayer: false});
                <!--Add layers to the map object-->
map.addLayers([blm_states,worldmap,Vector,sale_lease,blm_lease,blm_land]);
                <!--***NOTE: the order in which they are added determines
their order in the layer switcher menu-->
                <!--Add layer switcher menu (with custom color)-->
                var ls = new
OpenLayers.Control.LayerSwitcher({'div':OpenLayers.Util.getElement('layerswitcher'),activeColor:'#660066'})
                map.addControl(ls);
                <!--Add lat/long read-out to the menu-->
                map.addControl( new OpenLayers.Control.MousePosition() );
                <!--Add zoom and pan controls to map-->
                var panel = new OpenLayers.Control.NavToolbar();
                map.addControl(panel);
                map.addControl(new OpenLayers.Control.Scale($('scale')));
                <!--Have the layer menu already expanded when page is
loaded-->
                ls.maximizeControl();
                <!--Set the initial view of map using variables defined
above-->
                map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
    map.addControl(new OpenLayers.Control.OverviewMap());
    map.addControl(new OpenLayers.Control.Attribution());
    map.addControl(new OpenLayers.Control.SelectFeature('blm_lease'));
                <!--END OF OPEN LAYERS JavaScript-->
        </script>
    </head>
    <!--HTML-->
    <body onload="init()">
        <p style="font-family:verdana;font-size:10pt">
            LAND Object Service
        </p>
        <hr>
        <br>
       <!--LOAD MAP INTO A DIV-->
       <div id="controls">
            <div id="map" class="smallmap"></div>
       </div>
    </body>
</html>
View this message in context: http://n2.nabble.com/Feature-Info-tp3231951p3231951.html
Sent from the GeoServer developers mailing list archive at Nabble.com.
