[Geoserver-devel] File release system on sourceforge
sourceforge keeps on updating the file releases system making it every
time a little (or a lot) worse than it already was.
The situation on sf pages does not look good:
http://sourceforge.net/projects/geoserver/files/ -> wrong order, 1.3.0 on top
http://sourceforge.net/projects/geoserver/ -> Download now geoserver-2.0-beta2-chart...
"Wow, see, they got a 2.0 beta2 chart there!"
I know Jody fixed a bit the files page for GeoTools:
http://sourceforge.net/projects/geotools/files/
but the situation is still quite ugly
Time to ...:
- complain out loud with sf?
- move to greener pastures?
- just forget about it and hope that everybody will
   just use the geoserver.org links?
Andrea Aime
OpenGeo - http://opengeo.org
Andrea Aime wrote:
Time to ...:
I would definitely be interested in looking at alternatives to sf. Other than the annoying fact that they change things every time we release, there is the file release system itself. Releasing the dozen artifacts we have is very tedious having to submit for every artifact, scroll down the page to find the next and continue 12 times.
There has to be a more streamlined way to do this :slight_smile: Does anyone have any alternatives to sf in mind?
Justin Deoliveira
Justin Deoliveira ha scritto:
Andrea Aime wrote:
Time to ...:
Yup, "scp *.zip user@anonymised.com:path" should be all that's needed to ready
the files for download. And then we link them from our home page.
OSGEO? :wink:
Andrea Aime
Andrea Aime wrote:
Time to ...:
OSGEO? :wink:
All of SourceForge is currently struggling, apparently yesterday you couldnt even create directories.
I wouldn't mind giving them another month or two to figure out their system. The new one could potentially be better than all the pulldowns we had to deal with previously, and maybe we can reorganize things into an archive so that only the two most relevant releases are visible. Wouldn't do it right now though.
It's somewhat nice to think that they have a huge archive of all our stuff that it is actually somewhat difficult to lose due to the way it's distributed. Not doubting OSGeo's reliability, but I would definitely not trust S3 with this.
-Arne
Arne Kepp
The "new" file system manager let me connect with sftp and upload
files directly to the final spot. It was much nicer.
Jody
On Wed, Jul 29, 2009 at 11:01 PM, Justin Deoliveira<jdeolive@anonymised.com> wrote:
Andrea Aime wrote:
on top
Time to ...:
Justin Deoliveira
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
You mean it's not necessary anymore to point, click and submit 12 times
(once for each file to declare the file type) in order to have files
up?
Andrea Aime
up?
Nope, just pick a default download for each platform, the windows installer for Windows and the bin for the others.
That's why I'm cutting it some slack too :slight_smile:
-Arne
Arne Kepp
up?
If it is *please* point me to it. But I think Jody might just mean uploading the files, not actually publishing them. But I pray that I am wrong :slight_smile:
Justin Deoliveira
Here is the break down (they have several ways to uplaod files; there
web ui - which I find better then the last one - since you can upload
files and cut and paste them to move them between folders. Only trick
is I could not rename a folder; I had to move all the files out of it;
and then delete it).
There is sftp - you can see all the folders there - to hide something
move it into the folder "oldFiles". I also found I could move entire
folders (the old geotools milestones) into the "oldFiles" folder in
order to hide them.
They also listed SCP; Rsync but I did not try them.
Once you have files uploaded you can use the web ui to change what
type they are (platform independent etc - cannot say I bothered).
https://sourceforge.net/apps/trac/sourceforge/wiki/Release%20files%20for%20download
Jody
On Fri, Jul 31, 2009 at 12:45 AM, Justin Deoliveira<jdeolive@anonymised.com> wrote:
up?
Justin Deoliveira
Ok cool, things have changed for the better. Go sourceforge!!
order to hide them.
Jody
up?
Justin Deoliveira
Justin Deoliveira
