This is more a design question:
FileWatcher checks for external modifications of a file. But if tgeoserver code is writing the content of this file itself, how can I tell the FileWatcher NOT to indicate that the file is modified forcing an additional reload.
Proposals
1) add a method
setKnownLastModified(long lastModified)
2) add a method
write(T object)
which deserializes the object and adjusts the internal last modified timestamp.
Proposal 2 has another advantage. It is possible to detect conflicts if the file was changed externally and internally, throwing a proper IOException.
What do you think ?.
This message was sent using IMP, the Internet Messaging Program.
Proposals
1) add a method
2) add a method
write(T object)
timestamp.
IOException.
The first is probably more generic, does not require a case by case subclass,
but I'm wondering if this is an early optimization case.
Are the files in question so expensive to reload, or the expected
change rate of the file very high?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Please read below
Proposals
1) add a method
2) add a method
write(T object)
timestamp.
IOException.
In my case it is reading an XML file of unknown size, parsing, building a DOM and validate the DOM against an XML Schema.
Another Idea which does not hurt:
class WirteableFileWatcher<T> extends FileWatcher<T> {
public write(T object) trhows IOException() {
// code
Christian
On Thu, Jun 9, 2011 at 10:47 AM, <christian.mueller@anonymised.com> wrote:
Please read below
Proposals
1) add a method
2) add a method
write(T object)
timestamp.
IOException.
subclass,
Oh, I thought you were using xstream, which does not build a DOM,
uses a pull parser which is faster.
// code
Still prefer the file watcher to be notified. Otherwise it's no
more a file watcher but an almost full persistence subsystem
(if you write, why not read too while you're at it?).
The persistence subsystem could be built using the file watcher
services as a delegate.
Ing. Andrea Aime
Tech lead
Please read below
Proposals
1) add a method
2) add a method
write(T object)
timestamp.
IOException.
subclass,
You have the choice,
XStream xstream = new XStream(new DomDriver());
// code
Bought , should I prepare a patch for
Ing. Andrea Aime
Tech lead
Yep, thought it's a discouraged approach (because it's slow)
// code
Yep, go ahead
Ing. Andrea Aime
Tech lead
Last message here concerning building a DOM.
On reading I will use the pull parser and only validate if I get an exception. The xsd files
are in the GEOSERVER_DATA_DIR/security/..., users can user their own tool for validating
if the modify the xml files manually, I will point out this fact in the documentation.
On writing (GUI or hopefully REST in the future), I will always validate.
Christian
// code
Yep, go ahead
Ing. Andrea Aime
Tech lead
