I do mean the WFSDataStore. But if the SLD includes a filter, it should
provide this information also to the underlying dataStore, just for
optimization purposes...
Looking forward for further suggestions.
Theodor
-----Original Message-----
From: Jody Garnett [mailto:jgarnett@anonymised.com]
Sent: Wednesday, September 06, 2006 6:09 PM
To: Theodor Foerster
Cc: geoserver-devel@lists.sourceforge.net; GeoTools Devel List
Subject: Re: [Geoserver-devel] Filters within SLD
Good question, what do you mean by the WFS extention (do you mean WFS
Model for geoserver offering WFS service, or do you mean the
WFSDataStore used to chain GeoServer to a different WFS?).
The WFS Capabilities document does document how much of the filter spec
is supported, and your query is well within the limits. I really think
this is up to the renderer used, it will see WFS as a simple DataStore
and make the query as it sees fit.
Each renderer can make use of the SLD Filter information as it sees fit,
constructing many or one WFS request. There may be a hint for the
renderers that tell it to make many small queries ... lets ask GeoTools
devel.
Jody
Ok. But how is it the WFS extension doing? It should be able to
include the Filter in the request, but not filtering the Features out,
after receiving the complete Collection of the FeatureType.
Best regards
Theodor
Sent: Wednesday, September 06, 2006 3:23 PM
Theodor Foerster wrote:
I just try to get around myself, but I am really stuck. I would like
to have query, which actually is based on a defined SLD. The Filter I
added in the SLD looks like this:
<ogc:Filter xmlns:gml="http://www.opengis.net/gml">
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>TOLERANCE</ogc:PropertyName>
<ogc:Literal>17.5005</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
So now I have an attribute in the FeatureType, which looks like this:
new NumericAttributeType("TOLERANCE", Double.class, false,new
Double(0),
org.geotools.filter.FilterFactory.createFilterFactory().createCompare
F
il
ter(CompareFilter.COMPARE_EQUALS))
When the Query is passed to my DataStore at getFeatureReader(), I
only
can access the BoundingBox of the query. The actual Filter for the
property is not included. So what do I do wrong here? Is the type of
filter wrong?
No I do not think so, for a JDBCDataStore you get a chance to process
the filter and say what parts you support (sounds like bounding box),
and the "leftovers" are handled by GeoTools as a "post process" (aka
after you have returned all the ones that match the bounding box).
Depending on the renderer used they may just ask for *all* the
features in the bounding box, and then throw each feature past the
different Rules.
At least one of the Renderers has been "optimized" to make each Rule a
seperate datastore request. I know they did this on the complex
feature store branch - you may need to check what your version of
geoserver is doing.
Jody
--- Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
42 _______________________________________________
Geoserver-devel mailing list
