I might need you help in migrating gwc to Spring security too, if you'd
be so kind and we decide we want to migrate gwc from acegi too.
Gabriel
Of course I would. As far as I understand gwc, all authentication/authorization rules must hold for gwc too. I does not make sense to protect resources within geoserver and not protecting them from the cache. Is my understanding correct here ?.
At the moment I am banging my head against the wall. I migrated all projects needed for a
mvn clean install -PallExtensions.
I altered the class names contained in applicationSecurityContext.xml in the main module.
A "mvn compile" works fine.
But "mvn clean install" results in
ClassNotFoundException for org.springframework.vote.AffirmativeBased
when the applicationSecurityContext.xml file is processed.
Adding a line
System.out.println(System.getProperty("java.class.path"))
in the test case shows that all spring-security jars are in the class path.
The only documentation about migrating I found is here
http://java.dzone.com/tips/pathway-acegi-spring-security-
The author did not migrate the old security xml file, he created a new one, which uses xml name spaces. I tried the same and as result, I get a parsing error "element beans:beans is missing", but it is there. It seems that the XML parser is not namespace aware.
For the moment, I have no further idea, perhaps I have to download all necessary source jars and have an in dept debugging session.
Is there an svn repo for gwc ?. Perhaps I could try with gwc to find the problem.
so far, so good
Christian
This message was sent using IMP, the Internet Messaging Program.
