[Geoserver-devel] [gdal-dev] GML lat-lon coverages and interoperability
Gdalinfo about my test image “4326.jp2”:
Size is 15518, 7355
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (24.724834097819130,61.783882749023277)
Pixel Size = (0.000007567519986,-0.000007567519986)
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 24.7248341, 61.7838827) ( 24d43’29.40"E, 61d47’ 1.98"N)
Lower Left ( 24.7248341, 61.7282236) ( 24d43’29.40"E, 61d43’41.61"N)
Upper Right ( 24.8422669, 61.7838827) ( 24d50’32.16"E, 61d47’ 1.98"N)
Lower Right ( 24.8422669, 61.7282236) ( 24d50’32.16"E, 61d43’41.61"N)
-Jukka-
Lähettäjä: andrea.aime@…403… [mailto:andrea.aime@…403…] Puolesta Andrea Aime
Lähetetty: 3. huhtikuuta 2017 16:31
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Kopio: ‘gdal-dev@…1232…’ (gdal-dev@…1232…) <gdal-dev@…1232…>; geoserver-devel@lists.sourceforge.net
Aihe: Re: [gdal-dev] GML lat-lon coverages and interoperability
On Mon, Apr 3, 2017 at 3:19 PM, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
<gml:Envelope srsName=“urn:ogc:def:crs:EPSG::4326”>
gml:lowerCorner61.7282236395245 24.7248340978191</gml:lowerCorner>
gml:upperCorner61.7838827490233 24.8422668729657</gml:upperCorner>
Can you clarify which one is longitude and which one is latitude? :slight_smile:
It’s one thing that really gets me about CITE tests too, if they wanted to make order obvious without further specs, the
coordinates of test data could have had some values greater than 90 :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
