[Geoserver-devel] GeoMDX module
Hello,
I first implementation of a geomdx datasource that work together with Mondrian is available
as a module for geoserver. The source code can be looked at https://github.com/befks/geomdx/
Best regards,
Eric Smets
Eric Smets                                    [eric.smets@anonymised.com](mailto:eric.smets@anonymised.com)
FKS bvba - Formal and Knowledge Systems       [http://www.fks.be](http://www.fks.be/)/
Schampbergstraat 32                           Tel:  ++32-(0)11-21 49 11
B-3511 Hasselt                                Fax:  ++32-(0)11-22 04 19
Glad you are enjoying GeoServer.
If you are in position to write a blog post for the GeoServer blog we always like to see successful projects. I am curious about the chalanges you ran into bridging the gap between GeoServer and OLAP?
You may wish to look at setting up a community module (even if all it does is have a pom.xml that pulls in your jars). This would also give you a chance to use a modern version of GeoTools. One thing to look forward to is ContentDataStore (I am asking teams to migrate from AbstractDataStore which you extend for MDXCachedDataStore).
On 13 February 2015 at 10:49, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
Best regards,
Eric Smets
Eric Smets                                    [eric.smets@anonymised.com...](mailto:eric.smets@anonymised.com)
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
Jody Garnett
