[Geoserver-devel] GEOS-3206
Hi Simmone, if you want to write or comment, write it and close this issue with a WON`T FIX.
Looking at 3) from the last comment of jonathan is a proposal for creating an xml mapping file for jdbc databse with a tile utility. No !
Anyway, the improvement was to improve the documentation/tutorial giving a link to the fwtools which is easy to install and was a very good hint. Thanks to Jonathan.
