[Geoserver-devel] GEOS-8414 - Allow user to specify a "base layer" for layer previews and style preview
Hi Everyone,
I thought I would move this discussion to the development list as well.
I think this one may be more of note to self for Ian Turton as this is likely a much bigger change than I would be looking to undertake during my learning period.
The comment raised was:
For many layers it is useful to be able to see the layer over a base layer, especially when designing a new style. It would be nice if a user could specify a base layer in the previews without hand editing the browser URL.
On Mon, Nov 27, 2017 at 3:22 PM, Paul Wittle via Geoserver-devel <
geoserver-devel@lists.sourceforge.net> wrote:
I did note that you can achieve it using the reflector and Ian noted that
it can actually be achieved using the normal layer preview as well however
some of the other functionality of the page is impacted if you render two
layers in the preview. This may not be the case if the base layer was
actually a base layer type in the OpenLayers map. The simplest method could
actually just be to add OSM as the default base map as an option but we
could just make it fully controlled by a configuration option anyway.
I think it would be nice to have a set of options, but there is a catch...
most options are in 3857, and most data is in something
else, so a reprojection would be needed.
This is a "no go" imho for the normal layer preview, as it is not uncommon
to have data with mis-setup CRS (invalid in the data, or
mis-guessed), if not "EPSG:404000" (no CRS).
In those cases no seeing anything on map would case confusion, as there are
multiple reasons for that to happen.
It would also require a redesign of the preview page and break the SRS/CRS
parameter support (the preview is itself a GetMap request).
However, at least for the style editor preview... why not? The layer
preview would stay there for the simple data verification with no
magic in between, while the view in the editor is indeed meant for
verification of the style being edited.
GeoServer Professional Services from the experts! Visit GeoSolutions Enterprise Support Services
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
That sounds reasonable enough to me, as I said I’m looking for simple tasks I can work on so perhaps I could just take a look at the style editor as you say?
Once added I wonder if the various previews need more reference to each other as it seems from the discussion that each preview has a specific function yet speaking as more of an end user at this point I would say many users would expect all of the functions to be described as Layer Preview. There is no reference on that page to the style editor preview or to the tile layers preview and so for me the purpose of the page is perhaps a little misleading to someone that is not as close to the development of the application.
To give an example, if I were setting up a layer I would definitely make use of the style editor preview however if I was not using GeoServer much and have only logged on because of an end user complaining about a layer which is not drawing correctly I know for a fact they always go to the Layer Preview link. I’ve watched my colleagues do it and I’ve done it myself. That usually works but not if the layer has a maximum scale at which it renders as discussed.
In the case of the tile preview, the current link states Tile Layers so it doesn’t necessarily draw users to it in the same way as Layer Preview; perhaps it should be called Tile Preview?
As always please feel free to disagree but I’m definitely happy to take a look at the style editor if that is the preferred option.
Paul
On Mon, Nov 27, 2017 at 3:22 PM, Paul Wittle via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
I did note that you can achieve it using the reflector and Ian noted that it can actually be achieved using the normal layer preview as well however some of the other functionality of the page is impacted if you render two layers in the preview. This may not be the case if the base layer was actually a base layer type in the OpenLayers map. The simplest method could actually just be to add OSM as the default base map as an option but we could just make it fully controlled by a configuration option anyway.
I think it would be nice to have a set of options, but there is a catch… most options are in 3857, and most data is in something
This is a “no go” imho for the normal layer preview, as it is not uncommon to have data with mis-setup CRS (invalid in the data, or
mis-guessed), if not “EPSG:404000” (no CRS).
In those cases no seeing anything on map would case confusion, as there are multiple reasons for that to happen.
It would also require a redesign of the preview page and break the SRS/CRS parameter support (the preview is itself a GetMap request).
However, at least for the style editor preview… why not? The layer preview would stay there for the simple data verification with no
magic in between, while the view in the editor is indeed meant for verification of the style being edited.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 29, 2017 at 8:52 AM, Paul Wittle <P.Wittle@anonymised.com>
wrote:
Hi Andrea,
as you say?
Working on the UI is hardly the easiest task you can pick, Wicket does not
have a gentle learning curve. But you have to start from somewhere, so that
might be a case.
application.
The preview is meant mostly for the admin to run tests while setting up
layers and as a quick way for users to have a peek at the data.
What most users would like to see is instead a full blown client where they
can look at various layers, in full page form, with a background and the
like, maybe with the ability to add remote layers, maybe with tools and so
on. There is no such a thing in GeoServer, I have been suggesting for a
while in my company to build a simple one around MapStore2, to be delivered
as a plugin, but I'm getting no traction.
See above, it's a "no go" because in order to use a common background we'd
need reprojection in the mix
The "Tile layers" page is not visible to common users, only to admins.
Please read carefully my answer on the other thread and let's talk about
tiled
preview there please (one thread, one topic).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
I think that summarises it well but just for clarity when I say end user I am referring to admin users rather than members of the general public; we don’t advertise the GeoServer administration pages for our deployment. I’m primarily suggesting that even some admin users would not necessarily understand the nuances of the different previews if it was not explained to them. That said, GeoServer is an international project so I probably wouldn’t expect them to.
I note your point regarding the Wicket learning curve; how long can a ticket remain open?
If we change the scope of this ticket to be adding the base map to the style editor and assign it to me (if that is what you do with tickets) then I’m happy to look at it but as you say it might be a while. If that is problematic then we could simply close the ticket and open a new one when I’m ready to actually make the specific pull request for the change.
Final point noted, I will reply there.
Paul
On Wed, Nov 29, 2017 at 8:52 AM, Paul Wittle <P.Wittle@…4807…> wrote:
Hi Andrea,
Working on the UI is hardly the easiest task you can pick, Wicket does not have a gentle learning curve. But you have to start from somewhere, so that might be a case.
The preview is meant mostly for the admin to run tests while setting up layers and as a quick way for users to have a peek at the data.
What most users would like to see is instead a full blown client where they can look at various layers, in full page form, with a background and the like, maybe with the ability to add remote layers, maybe with tools and so on. There is no such a thing in GeoServer, I have been suggesting for a while in my company to build a simple one around MapStore2, to be delivered as a plugin, but I’m getting no traction.
See above, it’s a “no go” because in order to use a common background we’d need reprojection in the mix
The “Tile layers” page is not visible to common users, only to admins. Please read carefully my answer on the other thread and let’s talk about tiled
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 29, 2017 at 9:19 AM, Paul Wittle <P.Wittle@anonymised.com>
wrote:
Hum... I see. I would not mind much renaming "tiled layers" into "tiled
preview" but there are thing in that page like disk quota, seeding and
clean links that are not previews.
However you have a point, I seldomly use that page myself, keep on
forgetting that is there, mostly because if I want to configure tile
caching I go to the layer and then switch to the tile caching tab... so
yeah, that page is indeed problematic from that point of view.
Maybe it's also the location of the page in the menu, one edits
layers/styles first, and the "tile layers" link is a few sections down.
Wondering if moving "tile caching" up, right below "Data" in the menu,
may help some with that.
And maybe also splitting the tile preview, which would be visible to all,
and have a tile layers page that has the remaining things (disk quota,
seed, clear), which is visible only to admins.
ticket remain open?
Given the recent discussion, a improvement/new feature ticket will stay
open one year before being closed. A bug report one does not get closed
instead.
(the cleanup of old feature requests is yet to be done, mind)
No problems. Assigning tickets is something we do when someone starts
working on them, otherwise users can get the false impression that the
ticket is being
taken care of, while it is not (sometimes people assign the ticket and then
stop working and forget to un-assign, but you should see that most of the
tickets
are in unassigned state)
Thank you! :slight_smile:
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Aaand… I ended up talking about tiled layers in the wrong thread… oh well!!!
On Wed, Nov 29, 2017 at 9:32 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Nov 29, 2017 at 9:19 AM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Hum… I see. I would not mind much renaming “tiled layers” into “tiled preview” but there are thing in that page like disk quota, seeding and clean links that are not previews.
However you have a point, I seldomly use that page myself, keep on forgetting that is there, mostly because if I want to configure tile caching I go to the layer and then switch to the tile caching tab… so yeah, that page is indeed problematic from that point of view.
Maybe it’s also the location of the page in the menu, one edits layers/styles first, and the “tile layers” link is a few sections down. Wondering if moving “tile caching” up, right below “Data” in the menu,
And maybe also splitting the tile preview, which would be visible to all, and have a tile layers page that has the remaining things (disk quota, seed, clear), which is visible only to admins.
Given the recent discussion, a improvement/new feature ticket will stay open one year before being closed. A bug report one does not get closed instead.
No problems. Assigning tickets is something we do when someone starts working on them, otherwise users can get the false impression that the ticket is being
taken care of, while it is not (sometimes people assign the ticket and then stop working and forget to un-assign, but you should see that most of the tickets
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
