I all,
I have installed geoserver 1.7.2 from war in tomcat55 on a debian 40r5.
Geoserver throws an error when I try to publish e geotiff dataset, error following:
INFO: Illegal access: this web application instance has been stopped already. Could not load it.geosolutions.imageio.stream.input.FileImageInputStreamExtImpl. The eventual following stack trace is caused by an error thrown for debugging purposes as well as to attempt to terminate the thread which caused the illegal access, and has no functional impact.
java.lang.IllegalStateException
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1241)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1201)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi.createInputStreamInstance(FileImageInputStreamExtImplSpi.java:145)
I have succeeded ti publish same dataset in same environment in geoserver 1.7.1a
If I run geoserver 1.7.2 under root instead of tomcat55 users everything works fine.
Just to report
Hi Andrea,
I have downloaded geoserver 1.7.2 war and I have deployed on Tomcat55 on Ubuntu 8.04.
No errors were occurred here.
I’m still investigating on your issue.
Daniele
On Tue, Jan 27, 2009 at 10:34 AM, Andrea Cappugi <kappu72@anonymised.com…> wrote:
I all,
Just to report
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
Geoserver-devel mailing list
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
