[Geoserver-devel] GeoServer 2.10-beta artifacts ready for testing
Hello everyone,
The GeoServer 2.10-beta artifacts are ready for testing:
http://ares.boundlessgeo.com/geoserver/release/2.10-beta/
The OS X DMG is currently unavailable - there seems to be an issue with the build box. Working to get a fix for that right now (and thanks to Devon for fixing the OS X build script)
Torben
OS X DMG looks mostly good.
I am seeing an exception on startup:
java.io.IOException: Exception in finding browser: com.apple.mrj.MRJFileUtils
at org.geoserver.console.Browser.openUrl(Browser.java:613)
at org.geoserver.console.GeoServerConsole$Frame.started(GeoServerConsole.java:558)
at org.geoserver.console.GeoServerConsole$Frame$7.run(GeoServerConsole.java:527)
It looks like the code that automaticaly opens GeoServer in the browser is broken in the DMG install. The server still starts up fine though, and can be reached from localhost:8080/geoserver.
Torben
On Mon, Sep 19, 2016 at 4:59 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello everyone,
Torben
Hi Torben,
I was checking with Nuno, the issue blocking 1.9.x is also affecting this beta.
If someone is careless (no backup) and unlucky (the issue does not happen to everybody, it’s
an application context loading order draw of the luck) the beta test can result in losing all the
cached layer configurations… which of course could be (pretty) bad.
This is a beta after all, and testers should not expect it to be fully functional or safe,
but we should at least say something.. and if we do, less people will dare installing it I’m afraid.
On Tue, Sep 20, 2016 at 1:59 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello everyone,
Torben
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
This is GEOS-7750, correct? I’ll ad a note/warning to the release anouncements for the beta. Thanks for the heads up.
Torben
On Tue, Sep 20, 2016 at 3:09 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
Hello everyone,
Torben
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Torben,
yes, that’s the one
On Tue, Sep 20, 2016 at 5:16 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Hi Torben,
Hello everyone,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Yup that’s the issue.
Torben
Hi Torben,
but we should at least say something… and if we do, less people will dare installing it I’m afraid.
Hello everyone,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
mob:   +39  333 8128928
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
The Windows geoserver-2.10-beta.exe was missing. This occured because the Windows build box had run out of memory. This is now fixed, and geoserver-2.10-beta.exe has been uploaded to ares and sourceforge.
I have done a basic test in a Windows VM, and a default install works fine.
I should have the release anouncement out shortly
On Tue, Sep 20, 2016 at 8:31 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Torben
[Geoserver-devel@anonymised.comsourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
@nmcoliveira
Software Engineer
Hi Torben,
Hello everyone,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Draft blog post here, if anyone wants to take a look: http://blog.geoserver.org/wp-admin/post.php?post=2702&action=edit
If anyone knows of any other beta testing priorities, please let me know. Currently I have listed the following priorities for testing:- Updated GeoServer Style Editor
Torben
On Tue, Sep 20, 2016 at 11:57 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
On Tue, Sep 20, 2016 at 8:31 AM, Nuno Oliveira <nuno.oliveira@anonymised.comit> wrote:
Torben
[Geoserver-devel@anonymised.comrge.net](mailto:Geoserver-devel@lists.sourceforge.net)
@nmcoliveira
Software Engineer
Hi Torben,
Hello everyone,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Torben,
I added some bullet points on the coverage WMS GetFeatureInfo changes. Feel free to edit, or ask for improvements if they do not make sense (I went for brevity not completeness).
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks Ben, the changes look sensible enough to me.
Torben
On Tue, Sep 20, 2016 at 1:32 PM, Ben Caradoc-Davies <ben@anonymised.com.> wrote:
Torben,
Kind regards,
Ben.
Director
Transient Software Limited <http://transient.nz/>
New Zealand
