Hi Team,
the small “2.3.1” link of the GeoServer download page listed in the “GeoServer 2.13 releases” doesn’t work.
The GeoServer download page: http://geoserver.org/download/
Note however that the BIG " GeoServer 2.13.1" link beside the green “Stable” label works.
The 2 links refer indeed to different places:
The big font one: http://geoserver.org/release/stable
The small one in the list: http://geoserver.org/release/2.13.1
Not sure if this needs a JIRA or not (let me know if I need to open one) since I don’t know how the download site is built/populated.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi again,
I have created a PR for this:
https://github.com/geoserver/geoserver.github.io/pull/66
Hope it is the right fix.
Daniele
On Fri, Jul 6, 2018 at 5:41 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com…> wrote:
Hi Team,
Daniele
Daniele Romagnoli
Daniele Romagnoli
Yes, that looks like the correct fix. Looking at my local files, it seems that I just forgot to add that file to my commit when doing the 2.13.1 release. I’ve merged your PR, and the link appears to be working now.
Torben
On Fri, Jul 6, 2018 at 9:28 AM, Daniele Romagnoli <daniele.romagnoli@anonymised.com68…> wrote:
Hi again,
Daniele
On Fri, Jul 6, 2018 at 5:41 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.comsolutions.it> wrote:
Hi Team,
Daniele
Daniele Romagnoli
Daniele Romagnoli
