[Geoserver-devel] GeoServer 2.15.3 artifacts ready for tests
the 2.16.0 release artifacts have been built and are ready for testing at:
https://build.geoserver.org/view/release/job/geoserver-release/lastSuccessfulBuild/artifact/distribution/2.15.3/
Can anyone give them a spin before I go full publish?
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
