Artifacts are available for pre-flight testing here:
https://build.geoserver.org/view/release/job/geoserver-release/137/artifact/distribution/2.23.5/
This includes the windows installer.
Tomorrow I’ll proceed with the publishing, if there are no issues found.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
