[Geoserver-devel] Geoserver 2.24.2 artifacts available for preflight testing
Artifacts are available for pre-flight testing here:
Release notes: https://github.com/geoserver/geoserver/releases/tag/2.24.2
Draft blog post is available for review: https://github.com/geoserver/geoserver.github.io/pull/180
Pending feedback I would like to release tomorrow, to avoid getting too close to the weekend.
Jody Garnett
I have installed version 2.24.2 as war-file under Tomcat 9.0.82 - so far everything seems to be working normally.
Georg
Am 24.01.2024 um 03:02 schrieb Jody Garnett:
Jody Garnett
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Hi Jody
Thanks for the release artefacts. I was able to use winsetup to install to Windows, manually downloading and adding the extensions that I use. GeoServer 2.24.2 ran with our most complex configurations, however, I was not able to fully test as I have not yet set up JNDI on this Windows laptop. I will still try to do that some time.
However, as mentioned before, it might be far more useful to test against a docker pre-flight image, if that is available.
I was able to determine from
https://github.com/geoserver/geoserver/tree/2.24.x and
https://github.com/geotools/geotools/tree/30.x
(but ignoring the recent https://github.com/GeoWebCache/geowebcache/tree/1.24.x commits)
that there were no commits in the last 24 hours, so the most recent https://build.geoserver.org/view/geoserver/job/geoserver-2.24.x-nightly/ should have produced a 2.24.x docker image at https://docker.osgeo.org/#browse/browse:docker:v2/geoserver/tags/2.24.x that approximates these pre-flight artefacts. (Actually, I see this docker image was produced 10 hours ago, when you built the release. Did you kick off another job, or is that now part of the automated release process?)
Should we add to the “artefacts available” email a link/reference to the docker image for more developers to test against?
Anyway, testing against this 2.24.x docker image was successful, including JNDI and all the extensions that we make use of. LGTM.
Peter
Jody Garnett
Hi Peter,
You should be able to test against docker yes.
I am testing the maven artifacts today also.
Jody Garnett
Jody Garnett
Thanks for feedback and testing, proceeding with release step.
Peter we can have a moment to test Docker before announcing.
Jody Garnett
Jody Garnett
Jody Garnett
