[Geoserver-devel] GeoServer 2.25.1 release train
I notice that both Ian and myself have signed up for the release this month :slight_smile:
It was my intension to do the stable releases when I have an opportunity to do so - by collaboration is good :slight_smile:
Are there any pull requests in need of review ahead of release? I see that the 18th falls on a Saturday so I am likely to set the release on Monday 20 May, and announce the following day (if everything goes well).
Jody Garnett
Checking in ahead of release,
I am ware of https://github.com/geoserver/geoserver/pull/7580 needing review.
Are their any other pull requests in need of review and backport ahead of 2.25.1 release?
Jody Garnett
Jody Garnett
I would like to do the release today, there was
some build instability last week (thanks for fixing Andrea and Peter).
I have one PR to check (hopefully it has been reviewed) before release.
Jody Garnett
Jody Garnett
Jody Garnett
Preflight artifacts available for testing https://build.geoserver.org/view/release/job/geoserver-release/141/artifact/distribution/2.25.1
Jody Garnett
Jody Garnett
Blog post ready for review: https://github.com/geoserver/geoserver.github.io/pull/196
Please check it over and we can announce tomorrow.
Please note that the docker build is down due to credential change at repo.osgeo.org - Johannes Weskamm has the credentials that were used. Let me know if you can fix it; or if I should generate something else tomorrow?
The job to re-run is https://build.geoserver.org/view/release/job/geoserver-release-docker/1021/ (parameters version 2.25.1 build 82)
Jody Garnett
Jody Garnett
Jody Garnett
As i do not have access to the build infrastructure, someone else will have to fix the credentials, either by contacting me to get the password or by creating a new password / another account for the build.
The account i have was originally intended for deploys from github action pipelines into the osgeo repo, but things turned out different.
So if you need any input from my side just let me know.
Greetings,
Johannes
Am 23.05.24 um 06:01 schrieb Jody Garnett:
Jody Garnett
On May 22, 2024 at 6:09:46 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On May 13, 2024 at 11:07:01 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Dipl.-Geogr. Johannes Weskamm
  — Anwendungsentwickler —
  terrestris GmbH & Co. KG
  Kölnstraße 99
  53111 Bonn
  Tel: +49 (0)228 / 96 28 99 -51
  Fax: +49 (0)228 / 96 28 99 -57
  Email: [weskamm@anonymised.com](mailto:weskamm@anonymised.com08...)
  Web: [https://www.terrestris.de](https://www.terrestris.de)
  Amtsgericht Bonn, HRA 6835
  Komplementärin: terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Torsten Brassat, Marc Jansen
  Informationen über Ihre gespeicherten Daten finden Sie auf
  unserer Homepage unter folgendem Link:
  [https://www.terrestris.de/datenschutzerklaerung/](https://www.terrestris.de/datenschutzerklaerung/)
Thanks Johannes, I think I can grant the gsbuilder account docker permission (that way the build server will just have one set of credentials for repo.osgeo.org).
I have tested the downloads, and the release announcement has now been reviewed (thanks Peter and Andrea).
I will have a go at fixing docker and then release either way.
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Fixed, docker for 2.25.1 should now be available.
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
