I understand, I have had some luck with the latex build pipeline in another context, but ended up with various restrictions on what RST syntax can be used (in order to avoid errors creating PDFs). Mark Leslie would have more details on what to avoid.
However for the direct issue of image handling I have an answer discovered earlier this month.
To handle images consistently for both HTML and PDF:
… image:: foo.png
:width: 100% ← to make sure we start within bounds
:scale: 80% ← scale is adjusted from above width, change percentage to make content consistent in final output
So some examples would be:
… image:: webpage.png
:width: 100%
:scale: 100%
… image:: windows_installer_wizard.png
:width: 100%
:scale: 60%
… image:: open_layers_preview.png
:width: 100%
:scale: 80%
… image:: config_page_detail.png
:width: 100%
:scale: 30%
But yeah until the PDF is cleaned up may as well leave it out. You can even indicate a volunteer is needed in your release announcement.
Jody Garnett
On Sunday, 21 April 2013 at 3:08 AM, Andrea Aime wrote:
another thing that is not build by the build server is the DPF docs.
I’ve installed virtually every package with latex in its name (well over a GB of stuff) but the build keeps on giving me hundreds of errors, and in the end the generated PDF does not contain a table of contents…
Given all the hurdles with generating the PDF, and generally speaking, how bad the PDF looks vs images contained in it (they are very much oversized) I’d suggest to just drop the PDF as part of our downloads.
Opinions?
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Precog is a next-generation analytics platform capable of advanced
analytics on semi-structured data. The platform includes APIs for building
apps and a phenomenal toolset for data science. Developers can use
our toolset for easy data analysis & visualization. Get a free account!
http://www2.precog.com/precogplatform/slashdotnewsletter
Geoserver-devel mailing list
