On Thu, Apr 21, 2016 at 1:04 PM, Brad Hards <bradh@anonymised.com> wrote:
> Did you set a data dir? Or are you running off the internal one?
Should be running off default (in /var/lib/tomcat/webapps/geoserver/data).
Interesting, this could be a regression then, potentially related to one of
the last refactors
in resource store, or as an alternative (seems a bit less plausible, but
not impossible) to
the wicket upgrade.
I'd open a bug report marking it as blocker for RC1 (all regressions
normally are).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
