Hi guys,
The build failure seems due to no-space left on device.
Not sure this is the proper place to report but just in case someone can take a look at it…
Daniele Romagnoli
Visit http://bit.ly/gs-services-us for more information.
Daniele Romagnoli
Senior Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
