[Geoserver-devel] GeoServer clustering: Hitting "Reload" on the master raises exceptions on the slaves
Folks,
I have configured GeoServer Active Clustering in a master/slave configuration with embedded brokers.
The GeoServer version is 2.10.2, with Clustering and CSW extensions added. (The clustering extension was downloaded from:
http://ares.boundlessgeo.com/geoserver/2.10.x/community-latest/geoserver-2.10-SNAPSHOT-jms-cluster-plugin.zip.)
Changing the catalog on the master causes the updates to be mirrored faithfully on the slaves; however, when the "Reload" button is hit on the master, this exception is raised on the slaves:
2017-03-15 00:20:16.631Z] WARN [client.JMSContainer] - Setup of JMS message listener invoker failed for destination 'queue://Consumer.b41808d10cec.VirtualTopic.>' - trying to recover. Cause: java.lang.IllegalArgumentException: org.geoserver.wfs.WFSInfoImpl is not an interface
[2017-03-15 00:20:16.679Z] ERROR [geoserver.cluster] - class org.geoserver.cluster.impl.handlers.configuration.JMSServiceHandler is unable to synchronize the incoming event: org.geoserver.cluster.impl.events.configuration.JMSServiceModifyEvent@anonymised.com
[2017-03-15 00:20:16.680Z] WARN [client.JMSContainer] - Execution of JMS message listener failed, and no ErrorHandler has been set.
javax.jms.JMSException: java.lang.IllegalArgumentException: org.geoserver.csw.CSWInfoImpl is not an interface
         at org.geoserver.cluster.client.JMSQueueListener.onMessage(JMSQueueListener.java:149)
         at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:721)
Is this a bug (possibly an already solved one), or am I doing something wrongly?
Luca Morandini
Data Architect - AURIN project
Melbourne eResearch Group
Department of Computing and Information Systems
Room 3.08. Level 3, Doug McDonell Building, Parkville Campus
University of Melbourne
Tel. +61 03 903 58 380
Skype: lmorandini
LinkedIn: https://www.linkedin.com/in/lmorandini
On Wed, Mar 15, 2017 at 5:50 AM, Luca Morandini <lmorandini@anonymised.com> wrote:
Folks,
configuration with
embedded brokers.
(The
faithfully on
exception
I don't know about the specific error, but the documentation clearly
indicates that a reload should never be used along with the JMS clustering
extension:
http://docs.geoserver.org/latest/en/user/community/jms-cluster/index.html#things-to-avoid
I'm a bit surprised you did not end up ruining the slave's configuration...
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I don't know about the specific error, but the documentation clearly indicates
extension:
Well, it says that hitting "Reload" would trigger the complete rebuild of all resources on the slaves, which would be fine when adding empty instances to the cluster, I supposed.
It was empty (separate data dirs), not much to ruin there.
So, when adding a new instance, shall I stop accepting catalog changes, copy the data dir to the new instance, connect the new (slave) instance to the master, and then restart accepting catalog changes?
Luca Morandini
Skype: lmorandini
On Wed, Mar 15, 2017 at 8:48 AM, Luca Morandini <lmorandini@anonymised.com> wrote:
indicates
> extension:
all
to the
When it says "things to avoid" it really means it, I had data dirs busted
by doing
that by accident (training setup, I was not aware the clustering was
already on
while doing the basic parts and hitting reload willy-nilly...)
configuration...
copy the
master, and
I'm not sure, but yes, that seems like a legit approach. For a elastic
scaling approach
I'd rather go for shared data directory, only master writes, and remember
to separate
the logs.
Ing. Andrea Aime
@geowolf
Technical Lead
On 15 March 2017 at 08:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
I also interpreted that documentation as being “it will take ages” rather than “it will break things”.
Presumably stopping & starting the master instance will effectively trigger a complete rebuild of all slave resources too during catalog startup? Or is reload special somehow?
Rob :slight_smile:
I don’t know about the specific error, but the documentation clearly indicates
extension:
Well, it says that hitting “Reload” would trigger the complete rebuild of all
When it says “things to avoid” it really means it, I had data dirs busted by doing
that by accident (training setup, I was not aware the clustering was already on
while doing the basic parts and hitting reload willy-nilly…)
On Wed, Mar 15, 2017 at 12:15 PM, Robert Coup <robert.coup@anonymised.com>
by doing
already on
I also interpreted that documentation as being "it will take ages" rather
than "it will break things".
Pull requests to reword that welcomed :-p
Ing. Andrea Aime
@geowolf
Technical Lead
On 15 March 2017 at 11:29, Andrea Aime <andrea.aime@anonymised.com> wrote:
I can.
Current wording is a bit more bold that I remember:
On Wed, Mar 15, 2017 at 12:15 PM, Robert Coup <robert.coup@anonymised.com> wrote:
NEVER RELOAD THE GEOSERVER CATALOG ON A MASTER: Each master instance should never call the catalog reload since this propagates the creation of all the resources, styles, etc to all the connected slaves.
Followup question:
With a master-writes and shared data-directory/DB approach… restarting the master seems fine. But reloading will cause issues? Making some assumptions:
  1. reload doesn’t pass a “destroy” message across the cluster, so on a slave everything is created on top of the previous objects?
  2. normal webapp startup suppresses create messages across the cluster?
But if you have slaves that can write to a shared data-directory/DB, seems like any catalog edits will make you have a bad day?
Rob :slight_smile:
