[Geoserver-devel] geoserver-devel discourse or google discussions?
Okay I am about to package up geoserver-devel mbox for search archive on discourse GeoServer / devel … this restores the search ability we lost when nabble went away.
And wanted to ask what to do next:
  1. We can use the GeoServer / devel forum just fine as a mailing list
  2. We can enable google discussions on our github repository.
    I see other pygeoapi doing okay with this approach; and it is the one the core-geonetwork team favours as they make their own transition from sourceforge.
In sort I am ready to write a proposal for geoserver-devel as a follow up to GISP-225 - what would you like me to write up?
Jody Garnett
Hi Jody,
please let’s not start mixing approaches… we can have everything in discourse,
or everything in google discussions, or everything in the github “discussions”…
as long as we stick with one.
Using different solutions for the same problem (threaded and asynch communication)
is confusing.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Jody Garnett
