[Geoserver-devel] GeoServer developent with eclipse how-to.
I actually do not work with Eclipse and GeoServer.
Let's ask the geoserver devel list and see if anyone has some insight. In general you should email the list first, as I often don't know the answer and sometimes will just not get to replying. Emailing the list pretty much guarantees some sort of answer.
best regards,
Chris
Noorhoff, Ivo wrote:
Hello,
We are looking into using and extending GeoServer and I am trying to set up a Tomcat + Eclipse + GeoServer development enviroment based on this document :
http://docs.codehaus.org/display/GEOSDOC/GeoServer+and+Eclipse+with+Tomcat
It states :
"Click on Add Variable and if not exists create a new variable called GEOSERVER pointing to the lib sub-directory of the GeoServer source directory. Highlight the GEOSERVER variable and click on Extend.... Now select all the listed jars, not the directories, and click OK twice."
Problem is, a "lib" directory is nowhere to be found. Can you point me in the right direction ?
I've checked out the the 1.5.x branch and i'm using Eclipse 3.2.2.
Kind Regards, Ivo Noorhoff
<< Please read our E-mail Disclaimer at http://emaildisclaimer.grontmij.com >>
!DSPAM:1003,45f138f2257831665516417!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Hi Ivo,
That documentation page you found was ancient, I will remove it.
Refer to this one instead: http://docs.codehaus.org/display/GEOSDOC/Developer
cheers,
Brent Owens
(The Open Planning Project)
best regards,
Chris
Hello,
It states :
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-devel mailing list
