When I need to make multiple overviews for a large tiff I use the suggested workaround (making tif.ovr, tif.ovr.ovr, tif.ovr.ovr.ovr etc…).
This workaround works well for applications that use gdal (i.e. QGIS) but Geoserver’s internal GeoTiff reader ignores the multiple ovr files (I assume it reads only the tif+tif.ovr files) thus the performance for this map is very bad.
Workaround I found: I use the gdal-geoserver plugin and then create a trivial vrt for the tif and load it in Geoserver with the gdal plugin.
I needed to make a VRT because as far as I can tell Geoserver doesn’t register the GeoTiff format with gdal when the plugin is installed but still uses the internal GeoTiff reader).
A few questions:
Is there a plan to solve that very old gdaladdo bug? (I didn’t check with recent gdal versions but it still not marked as resolved as in 6 years)
Is it possible to make Geoserver recognize ovr.ovr files?
Can I make geoserver use the gdal plugin for GeoTiff files to avoid the trivial vrt file ?
Again, if you’re interested, you could spend time looking at the actual source issue and reinstate the plugin.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On lundi 14 janvier 2019 12:00:27 CET Idan Miara wrote:
Due to the following bug: #5067 (gdaladdo slowness for large files) – GDAL
workaround (making tif.ovr, tif.ovr.ovr, tif.ovr.ovr.ovr etc...).
Geoserver's internal GeoTiff reader ignores the multiple ovr files (I
map is very bad.
I needed to make a VRT because as far as I can tell Geoserver doesn't
A few questions:
1. Is there a plan to solve that very old gdaladdo bug? (I didn't check
That could be very involved to fix that due to how things work in libtiff.
You can use the workaround suggested in the ticket to create a single file
from all the .tif, .ovr, .ovr.ovr, etc.
Sorry to hear that. Anyone is free to provide a fix or sponsor one.
As Paul Ramsey said (if memory serves me well) “in open source one gets what everybody else is paying for”. Current sponsored activity does not seem to match your needs, sorry
Even,
Thanks for your pointer!
It does solve the problem for me!
Andrea,
Thanks for you input!
Should I find the time to look into these issues I’ll contact you.
I’m working on a python wrapper for gdal translate/wrap/info python functions.
I’ll open source it once it’s done, hopefully it will help others with the issues I encountered.
On mercredi 16 janvier 2019 12:59:51 CET Idan Miara wrote:
Even,
Andrea,
Should I find the time to look into these issues I'll contact you.
I'm working on a python wrapper for gdal translate/wrap/info python
functions.
Hum, are you aware that they are already such wrappers in recent GDAL versions with the GDAL Python bindings ? gdal.Info(), gdal.Translate(), gdal.Warp() ?
I’m using this python API, I didn’t know theses tests which do help (as the python API is not as documented as the c++ API).
I feel we’re off topic here so I’ll publish it soon in another thread in the gdal-dev list.
Thanks!
Even,
Andrea,
functions.
