Reminder that the next PMC meeting is scheduled for tomorrow, February 2, at 17:30 UTC.
You can join the meeting via Jitsi: https://meet.jit.si/GeoServerMeeting
Torben Barsballe
Professional Services Engineer
Planet
Torben Barsballe
Planet
i will also join today as i’d like to talk about the progess on the docker image.
See you later,
Nils
Torben Barsballe
Planet_______________________________________________ Geoserver-devel mailing list [Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net) [https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
I’ll try to make it as well but I’ll probably be late.
Alessandro Parma
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
