There are a few little things wrong or missing.
First the 'manufacturer' is not Earth Resource Mapping. It's an open
source project, so there's no real manufacturer. But The Open Planning
Project started and maintains the project.
I'm not sure about your operating system list. Sun is just another
flavor of unix, so it should be supported as well. And since GeoServer is
written in Java, which is Sun's language, it doesn't make sense that their
OS wouldn't support geoserver.
Any webserver compliant servlet api 2.1 will work with geoserver.
For database we also support Oracle.
For GeoServer itself there are no client side requirements, that depends
on the specific WFS client, of which there are a few and more being built
all the time. We just serve data in an interoperable way. The data model
is vector.
The next release will support ArcSDE and WMS as well.
Java is the only language for interface customization.
Users can modify the database, as it is a transactional WFS, so you can
use direct xml requests or a good client.
Chris
On Wed, 26 Nov 2003, Greg Atkinson wrote:
Hello,
I am a graduate student at York University researching GIS and their
applications to the field of planning. I am working on a comparison of
map servers and would like to verify that the information I have
collected is accurate. Please see attached spreadsheet.
Thank you in advance for your cooperation,
Greg Atkinson
MES Candidate (Planning)
York University
