[Geoserver-devel] GeoServer Nigthly Build
Just wanted to notice that GeoServer Master Nightly build is currently failing due to this issue
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-assembly-plugin:2.1:attached (default-cli) on project geoserver: Unable to find descriptor: /var/lib/jenkins/workspace/geoserver-master/src/release/ext-vectortiles (No such file or directory) -> [Help 1]
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
On Mon, Oct 31, 2016 at 3:40 PM, Alessio Fabiani <
Maybe it's just missing the ".xml" part? Looks that way:
https://github.com/geoserver/geoserver/blob/master/src/pom.xml#L1405
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
