[Geoserver-devel] GeoServer PSC 2024-05-07
GeoTools / GeoServer PMC meeting - 2024-05-07### Attending- David Blasby
  • Peter Smythe
  • Jody Garnett
  • Andrea Aime
Actions from prior meeting:
  • [DONE] Jody: Make a PR for GSIP 224
  • [DONE] Peter: Make a similar proposal for GeoTools
  • [DONE] Jody: Make a Proposal for geoserver-users transition to discourse
Agenda:
Actions:
  • Jody: Make a ticket about GROUP_ADMIN not having permission to create a new user (GEOS-10938)
  • Jody: Make a ticket on clean up of admin roles and constants (GEOS-11389)
  • Jody: Open a ticket to refine Demo Page Javascript rewrite (GEOS-11390)
GSIP-224 - Individual contributor clarification
https://github.com/geoserver/geoserver/wiki/GSIP-224
  • Is this done? yes
GSIP-223 - Community module graduation, amending generality rule
https://github.com/geoserver/geoserver/wiki/GSIP-223
No PR, Jody made a PR? Can we merge …
GSIP-222 - Promote Raster Attribute Table module to extension
https://github.com/geoserver/geoserver/wiki/GSIP-222
What is the status?
  • Proposal was not completed by the time the release window…
  • Not sure if this is merged can we check? Yes …
  • 2.25 and main!
  • Updated Proposals page to indicate this is complete
GSIP-225 - Migrate geoserver-users from SourceForge to discourse
https://github.com/geoserver/geoserver/wiki/GSIP-225
  • Proposal was made, and approved
What happens next:
  • user list to discourse is a go, we will wait on SAC for the change
  • Expected some kind of PR for the website to provide instructions
  • Then notify users of the change
  • Proposal has shutting down the SF list after 1 month, and migrate any additional messages over
See proposal for details …
Encouragement from mastodon: https://fosstodon.org/@geoserver/112367510772585467
GeoTools proposal for individual contributors
https://github.com/geotools/geotools/wiki/Individual-contributor-clarification
50% response rate …
  • Torben is away so assume +0
  • No objections
  • Likely to pass on May 9th :smiley:
Could probably safely start the PR :grinning:
Security roles internals
Email questions
  • Hard to talk about due to naming “role_admin” “admin” “role_administrator”
  • Sometimes objects, sometimes strings
ROLE_ADMINISTRATOR
  • This is for the user interface, it unlocks the data admin console screens
ADMINISTRATOR
  • This is the “root” kind of access, often used for the REST API
  • Unlocks all the admin console for all the screens
GROUP_ADMIN
  • Unlocks the security admin console screens
The rest.properties is parsed:
GeoServerRole ADMIN_ROLE = new GeoServerRole(“ROLE_ADMINISTRATOR”);
GeoServerRole GROUP_ADMIN_ROLE = new GeoServerRole(“ROLE_GROUP_ADMIN”);
GeoServerRole AUTHENTICATED_ROLE = new GeoServerRole(“ROLE_AUTHENTICATED”);
GeoServerRole ANY_ROLE = new GeoServerRole(“*”);
GeoServerRole ANONYMOUS_ROLE = new GeoServerRole(“ROLE_ANONYMOUS”);
The https://github.com/geoserver/geoserver/blob/main/data/release/security/rest.properties file is parsed:
/**;GET=ADMIN
/**;POST,DELETE,PUT=ADMIN
Parsed by AbstractGeoServerSecurityService.java:
  • Has its own contents …
String DEFAULT_NAME = “default”;
String DEFAULT_LOCAL_ADMIN_ROLE = “ADMIN”;
String DEFAULT_LOCAL_GROUP_ADMIN_ROLE = “GROUP_ADMIN”;
XML Role Service allows you to nominate (for a role service):
  • Allows you to grant the internal administrator role to a role defined externally (like LDAP)
  • Allows you to grant the internal group administrator role to a role defined externally (like LDAP)
  • Does not have a group admin role; makes sense since they are not using the internal screens to manage users…
Trying out on empty data directory:
  • Defining a test role with workspace admin access worked as expected, data screens unlocked
  • Experimenting showed that GROUP_ADMIN did not behave as expected; it unlocked the security screen - but we did not have permission to add new users.
  • Action: Make a ticket about GROUP_ADMIN not having permission to create a new user
    https://osgeo-org.atlassian.net/browse/GEOS-10938
This shows an incomplete migration from GeoServer 2.1 to GeoServer 2.2:
  • It would be difficult to clean up, as the constants have become intermixed with the defaults in the data directory …
  • Andrea is trying with an empty data directory; to see what defaults are baked into the the application: → ADMIN, while ROLE_ADMIN is nowhere to be found
Ideas for a cleanup:
  • Many places in the code use either one or the other role (some smart ones, both)
  • Centralize the check that verifies both in a prominent place
  • Deprecate one of the two constants, make sure every admin check goes for the new method checking both
  • Remove the old one from the default geoserver data directory
  • Action: Make a ticket on clean up of admin roles and constants GEOS-11389
Record of meeting minutes
Sent to email list for later reference
Also transparency as PSC.
Chit chat
Should we remove the Demo Requests page?
  • Not sure how often it is used for training (its original purpose)
  • Can it be rewritten in Javascript? Yes if we have a Javascript developer.
    Action: Open a ticket to refine Demo Page Javascript rewrite GEOS-11390
