GeoTools / GeoServer PMC meeting - 2024-07-16### Attending- Torben Barsballe
Jody Garnett
Gabriel Roldan
Austin Joachim
Marc Risney
Kevin Smith
Andrea Aime
Peter Smythe
Actions from prior meetings:- [TODO] Torben: @ignore failing ogr-jni and vsi tests
[TODO] Torben: Update supported GDAL version in docs
[TODO] Add flag to fail imageio-ext-gdal tests if GDAL bindings aren’t found
[DONE] Jody: Reject recent geoserver-security join attempt: This is a volunteer list with no possibility to subscribe. Please contact geotools-devel if you wish to volunteer.
[DONE] Jody: Add something to our developers guide for geoserver-security list (in addition to SECURITY.md note)
Agenda- release schedule check-in
snowflake alpha
dev guide update(s)
FOSS4G Europe feedback
Discourse migration
chitchat
Actions- Jody: request or setup discourse channels (for screenshots)
Ian is set for Thursday release:
mapfish-print-v2 update (if we can)
would be lovely to have a v3 migration plan, or to lift and drop into geotools codebase
snowflake alpha
We have alpha release ready for review: congrats!
Austin and Marc presenting
geometry and geography types supported
discussion about JDBC datastores, what is most recent?
the core has the most recent tests, each plugin grabs them…
how much work to stay up to date?
have a look at history of an example:
https://github.com/geotools/geotools/commits/main/modules/plugin/jdbc/jdbc-mysql -
discussion on how community participation support works
things like oracle and so on that require infrastructure to test against attract less involvement
postgis and others get funding for new features and maintain all the time
community modules and maintenance:
modules maintained outside eventually peter out … have not had any long term maintained extensions
community modules offer on ramp and public review
geotools plugin is LGPL (permissive)
extensions get on the “basic maintenance” activities like refactors and api changes
online tests
would need some sponsorship from snowflake to provide a server to run against
https://github.com/geotools/geotools/blob/main/.github/workflows/oracle_online.yml
online tests are only run if ~/.geotools/snowflake.properites found with connection details
what about https://blog.localstack.cloud/2024-05-22-introducing-localstack-for-snowflake/
chris:
May be able to set up a CI/CD testings: 1 credit for 1 hour of compute
how much use? Up to the developers …
github workflow for each pull request
nightly builds
weekly online tests
repo.osgeo.org
repo.osgeo.org had some trouble
reached a number of components limitation → artificial warning to encourage sales pipeline
nexus ran out of space
check hsql or postgresql?
based on 30 users, it was 4k a year for commercial
we could get it down to under 10 users and requote
OSGeo and geoserver do not have enough sponsorship for this game …
each file is a “component” and pom and so on is listed as a component
jody adjusted clean up policies to get under 100,000… not a long term fix
alternative: we could split up into distinct instances for each repo
Can we just move on? Keep an eye on it …
dev guide update(s)- security policy: feedback
Discussion about including a POC in disclosure
POC when it is in the exploit tools?
So system admins can double check their instance is patched … -
CVE reached more people so the approach is a success
Use of Jira placeholder?
app schema updates?
jody tried updating docs as it was app schema was confusing
[GEOT-7616] Postgis_Data_ref_set.sql updates for modern PostGIS releases
has a few off topic qa changes describing test data since app schema does its own thing
Basic GeoServer workshop: well attended! Went well.
Some folks with newer (java 17 or java 21) had trouble
Removed marlin to continue with workshop
GeoServer includes a newer marlin because it is better / faster / fixes
Styling workshop also went well.
folks comfortable with editing style by hand
qgis geocat bridge demoed, generates good looking styles
aside: arcgis pro bridge is now available (on new website https://www.geocat.net/bridge/)
Presentations:
State of GeoServer: thanks Ian and Andrea
EO presentation was very popular, standing room, with STAC and WCS and so on
sponsorship? we need to ask more often …
aside:
- presentation on geoserver monitoring was really nice
Discourse migration
https://github.com/geoserver/geoserver/wiki/GSIP%E2%80%90225%E2%80%90working
Q: Do we set up a category for GeoServer then subcategories for users, developers, etc? Or different categories for each?
Original proposal suggests different categories for each
After more experience with Discourse, subcategories seem better - let’s go with this
Jody will update GSIP-225 accordingly
action:
jody: request or setup discourse category (for screenshots)
Peter: create PR for all pages with references to mailing list
chitchat
rest api duplicate post? Associate a user with a group twice → 409 response code is correct
if we make this change we break backwards compatibility? Is it worth it …
xml: succeeds and returns 200 → so change to 409 would break things
jdbc: throws an exception, 500 → so change to 409 is helpful
Peter: Would like to return a 200 (make jdbc the same as xml)
Andrea : In controller before associating the user with a group check if the association is already there → 409
Then you have no concern about about producing a primary key violation from JDBC backend
how about 204 (no content) meaning it’s idempotent?
solution:
- check first: if association is already there then return success, … less breakage, everyone happy?
about evolving rest api?
we were early, so the rest api does not follow modern conventions / good practices
so if we do a new one we would do something v2
marlin: https://github.com/geoserver/geoserver/pull/7760
- Marlin author likes geoserver as showcase of latest
ogcapi:
- gabe thanks everyone for their replies, continue
