GeoServer Meeting 2015-11-17
Attending
Ben Caradoc-Davies
Ian Turton
Jody Garnett
Torben Barsballe
Jukka Rahkonen
Andrea Aime
Kevin Smith
Brad Hards
Frank Gasdorf
Agenda
- Releases: 2.8.1 (etc), 2.7.4 (etc)
- CITE tests and build infrastructure
- Simplify Jira workflow
- Sprint Planning
- JAI Replacement Update
- Pull request/issue discussion
Actions
- Jody: merge GeoTools PR #1030 and backport to 14.x for 14.1/2.8.1
- Jody: merge GeoTools PR #1048 for 14.x for 14.1 release
- Ben: release 14.1/2.8.1
- Alessio: release 2.7.4
- Ben: simplify Jira workflow for GeoTools and GeoServer
- Jody: call for nominations for PSC on mailing list
- Jody: nominate Kevin Smith for PSC on mailing list
- Kevin: GeoTools / GeoServer - change from snapshot to main (to prevent HTTP 409). Kevin will prepare pull request
Actions from last meeting
- Andrea whitelist winbuild instead of subscribing [DONE]
- Jody: check CITE test problem with boundless IT [DONE, but not yet fixed]
- Ben: call for volunteers to migrate master to Java 8 [DONE]
- Jody: for Victoria code sprint, reach out to BC government, vivid
solutions, etc… - Ben: make a wiki page for the Victoria code sprint [DONE]
- Andrea : fill wiki page for code sprint
Releases
See release note:
https://github.com/geoserver/geoserver/wiki/Release-Schedule
GeoServer 2.7.4 release for GeoNode CodeSprint (please update the Release Schedule). Alessio is on point!
GeoTools PR #1030 and backport to 14.x for 14.1/2.8.1?
https://github.com/geotools/geotools/pull/1030 -
Jody will review, merge and backport to 14.x
Ben will wait for this before 14.1 release
GEOT-5302 see pull https://github.com/geotools/geotools/pull/1048 for Frank, Jody to commit for inclusion 14.1
GeoWebCache release? Not required, release GS 2.8.1 with GWC 1.8.0
Jetty startup failure, see mailing list for resolution.
- priority: May have a fix, see mailing list
- If possible use Jenkins instead of manual testing
- Future: Hook up new TE-2015 CITE tests from Andrea
- Ben to fix workflow (make new workflow and cut out extra states)
- Jody just granted full administrator rights to Ben
- Make a backup first
Sprint Planning
Victoria code sprint:
- https://wiki.osgeo.org/wiki/GeoServer_Code_Sprint_2016
- Week of Jan 18th (or week of Jan 11th)
- OSGeo Request for Funding Template (see https://wiki.osgeo.org/wiki/Code_Sprint_Guidelines need this filled in for Dec 10th meet)
- kevin: general feedback is we are not using wicket very well
- aaime: it is more fun that struts
Paris Code Sprint:
- We did consider this, but travel is cheaper to victoria
- See https://wiki.osgeo.org/wiki/Paris_Code_Sprint_2016
- Technical debt page: https://github.com/geotools/geotools/wiki/Replace-JAI (please help update this)
- LocationTech Steeting Committee: will worth with LocationTech to fundraise for development.
- OSGeo Board has responded positively: Will work with OSGeo to update downstream GeoTools / GeoServer and related project
- EclipseCon Europe - had a good discussion the “science working group”, and the GeoTrellis lead Rob Emanuele
- The replacement should be a joint LocationTech/OSGeo project.
- Still need a good name for this project (TileProcessingEngine, OpenJI, OpenTI (for tile imaging, OpenTIP)?
GeoServer Steering Committee
http://docs.geoserver.org/latest/en/developer/policies/psc.html
Jody: Nominate Kevin Smith as a member of the PSC.
Ben: +1 second
Take this to the mailing list.
Already covered:
- GeoTools PR #1030 - check contributor agreement and issue report
- GeoTools PR #1044 (GEOT-5298)
- GeoTools PR #1048 (GEOT-5302) - jody - merge and pick for master
- GEOT-5306 (daniele romagnoli required to review). Torben to take discussion to email
- GEOS-7270 nodata sections either from reprojection or in image may be filled in white in WMS. Behaviour varies between GeoTiff and other formats, and between JAI and JAI-EXT. (Looks like this QA issue in the JAI-EXT codebase on difference between background color and NO_DATA)
General Discussion:
- Q: Has warning “no a support forum” helped with useless bug reports for Geoserver? A: Yes it has helped.
- Q: Should we do the same for GeoTools? A: Not needed as the audience is developers
- Kevin: GeoTools / GeoServer - change from snapshot to main (to prevent HTTP 409). Action: Kevin will prepare pull request.
- Rate of pull requests has increased Andrea is unable to keep up. Jody and Ian have volunteer to help review.
- Discussion of error reporting (strip out frameworks from stack trace? Perhaps a bad idea).
