[Geoserver-devel] GeoServer PSC meeting notes, March 26th 2024
GeoTools / GeoServer PMC meeting - 2024-03-26Attending
   Andrea Aime
   Peter Smythe
   Jukka Rahkonnen
   Jody Garnett
Actions from prior meetings:
   Andrea: make a GSIP to amend the module graduation rules
   Next meeting:
      Interesting tile seeding speedup PR
      Sponsorship update from Jody
   jody: send invite to geoserver-security email list
   jody to set up an rst-fix branch to collect fixes, ideally with
   automation of mkdocs_translate
Agenda
   GSIP 222 and 223 status
   Tile creation speedup PR
   mkdocs update
   NetCDF dependency upgrade and backwards incompatibility
   Chit chat
Actions
GSIP 222, Graduating the Raster Attribute Table community module:
   Approved, past 10 days with enough +0 and +1, no negatives
   Andrea to make a PR to graduate the module
GSIP 223, Community module graduation, amending generality rule
   Andrea to make a documentation PR to update the procedures
Bunch of PRs at various levels to speed up tile generation:
   https://github.com/geosolutions-it/imageio-ext/pull/299 (sub-image
   encoding)
   https://github.com/GeoWebCache/geowebcache/pull/1227 (improved
   concurrency)
   https://github.com/geoserver/geoserver/pull/7457
      Enables the imageio-ext speedup
      Encode first tile on the request thread, delegate the others to a
      secondary thread pool
      Poor interaction with the mass-seed case, being worked on
Good stuff, thank you Mitchell Bösecke!
It has been a while since I've heard from him, we might have to complete
the development.
Problem with JMH tests. It should not be part of the quality test, because
the GitHub actions/jenkins is not reliable. For reference, GDAL is also
running performance tests, with 30% tolerance due to the unreliable
environment. See mail thread
https://www.mail-archive.com/gdal-dev@anonymised.com/msg39829.html
How to handle it:
   @Ignore and let them be run interactively
   Move them to the online profile?
   Make yet another profile?
   Add alongside other excludes:
   https://github.com/search?q=repo%3Ageoserver%2Fgeoserver+onlinetest+language%3A"Maven+POM"&type=code&l=Maven+POM
Only two use cases in a large code base, likely to get forgotten…
mkdocs update
Collect the rst changes.
Idea:
   Start from https://github.com/geoserver/geoserver/pull/7462
   Remove the mkdocs
   Collect the RSTs only
   Share the load of fixing the RSTs across various people
   Backport the changes
   Actually run the mkdocs
   https://github.com/jodygarnett/translate
Here are the instructions for running translate script:
   1.
   https://jodygarnett.github.io/translate/translate/migrate/
   mkdocs_translate init
   mkdocs_translate scan
   mkdocs_translate migrate
   2.
   Common problems:
   1.
      Too much indenting (results in a block quote)
      2.
      Stray ```` results in the rest of the file being wrong
      3.
   Examples also from previous RST PR:
   https://github.com/geoserver/geoserver/pull/7429/files#diff-7802f6ce973902c35df3d9c6670250c7191549c206ffbcccf20b6ae2582bb573L121
I am sorry Steve, it does look like this is an actual compatibility break
that cannot be addressed.
   GRIB file configured in GeoServer 2.25 will not actually work in future
   GeoServer 2.26!
   they changed 30-40 mapping tables in the library
   name of the variable is constructed at runtime (not read from the file
   it is constructed from header and how time is understood)
   Take down the layers and start from scratch; updates notes have
   instructions.
Can we provide an option in the upgrade guide to just hand-edit the files
instead? Only for single files…
Extra details and examples here:
https://osgeo-org.atlassian.net/browse/GEOT-7547
Chit chat
CVE Disclosure feedback / articles showing up.
   Difference between those seeking exposure vs to address an issue
