[Geoserver-devel] [Geoserver-users] SHAPE-ZIP Output Format - Multiple Feature Types
It's usually best to ask the list first to confirm that there is actually a problem. But if you are 100% sure, then by all means submit a bug report here:
http://jira.codehaus.org/browse/GEOS?report=com.atlassian.jira.plugin.system.project:roadmap-panel
cheers
Brent Owens
(The Open Planning Project)
Duncan Clarkson wrote:
Do you want me to submit issues like this direct to the bug tracker? Is this possible?
Duncan
Brent Owens wrote:
I think you might be right. I will add it as a bug report.
Thanks Duncan
Brent Owens
geoserver = 1.3.1
datastore = postgis 1.1.1
When I issue a WFS query and specify multiple feature types and shape output e.g.
some-wfs-query&typename=feature1,feature2,feature3&outputFormat=SHAPE-ZIP&
I only get the shape components for 1 feature i.e. I get a file called 'wfs' with the contents:
feature1.shp
feature1.dbf
feature1.shx
Shouldn't the file 'wfs' contain either 3 archives, one for each feature, or more simply 9 files: the .shp, .dbf and .shx for each of the features?
Duncan Clarkson
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1005,44aa9e96236902095110867!
