[Geoserver-devel] GeoServerExtensions and testing
In a review of pull request 568 Kevin asked me to look at making GeoServerExtensions easier to use with mock objects.
It is currently not too bad to use with an mock ApplicationContext:
GeoServerResourceLoader resourceLoader = new GeoServerResourceLoader(baseDirectory);
ApplicationContext context = createNiceMock(ApplicationContext.class);
expect(context.getBean(“catalog”)).andReturn(cat).anyTimes();
expect(context.getBean(“resourceLoader”)).andReturn( resourceLoader );
expect(context.getBeanNamesForType(GeoServerResourceLoader.class)).andReturn(new String{“resourceLoader”}).anyTimes();
expect(context.getBeanNamesForType((Class)anyObject())).andReturn(new String{}).anyTimes();
replay(context);
The downside is hooking it up:
new GeoServerExtensions().setApplicationContext( context );
I have added two static methods on pull request 568:
GeoServerExtensions.mock( context );
GeoServerExtensions.mock(“resourceLoader”, resourceLoader);
This covers Kevin’s request of making this easier for test cases.
These methods set an internal isMock field that is used to suppress warnings from checkContext - resulting in smaller output from our test cases. We may also be able to suppress some of the catalog created / destroyed information messages during testing as they are not adding value.
Jody Garnett
On Tue, Apr 22, 2014 at 9:25 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
        expect(context.getBean("catalog")).andReturn(cat).anyTimes();
        expect(context.getBean("resourceLoader")).andReturn(
resourceLoader );
String[]{"resourceLoader"}).anyTimes();
String[]{}).anyTimes();
        replay(context);
       GeoServerExtensions.mock("resourceLoader", resourceLoader);
I'm against having testing code creep into the normal API so explicitly.
Can we have a helper object that resides in testing packages that does
that, without pulluting GeoServerExtension
directly?
Meet us at GEO Business 2014! in London! Visit Visit GeoSolutions at GEO Business 2014 in London! - GeoSolutions
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I can change the method to be a bit less obvious, but we are kind of stuck
since GeoServerExtensions is acting a singleton (much like
GeoserverDataDirectory before it).
directly?
I am not quite sure how to make a testing only object to help out. Even if
we create one we still need to inject it into this singleton. I found a few
test cases manipulating the internal state of GeoServerExtension and I
figured methods were better for consistency.
Jody
On Tue, Apr 22, 2014 at 9:45 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Methods that can be of general use are ok, just not stuff that is clearly
geared towards testing, that has no place in normal API.
Ing. Andrea Aime
@geowolf
Technical Lead
I note the tension between a minimal API for development and opening the door for ease of testing.
Here is what I am testing now:
  • renamed the methods as init( name, bean ) and init( applicationContext ).
  • added a check to init(name,bean) to detect any conflict with applicationContext
  • changed the flag to isSpringContext, and the javadocs to describe additional consistency checks
Let me know if that is sufficient.
Jody Garnett
On Tue, Apr 22, 2014 at 5:53 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Apr 22, 2014 at 9:45 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Methods that can be of general use are ok, just not stuff that is clearly geared towards testing, that has no place in normal API.
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
Ing. Andrea Aime
@geowolf
Technical Lead
I can change the method to be a bit less obvious, but we are kind of stuck since GeoServerExtensions is acting a singleton (much like GeoserverDataDirectory before it).
I’m against having testing code creep into the normal API so explicitly.
On Tue, Apr 22, 2014 at 10:24 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
* renamed the methods as init( name, bean ) and init( applicationContext ).
* added a check to init(name,bean) to detect any conflict with
applicationContext
* changed the flag to isSpringContext, and the javadocs to describe
Looks better to me. It would be nice if Justin could have a look as well
Ing. Andrea Aime
@geowolf
Technical Lead
Yep, I will finish testing and hold off hitting merge until we hear from Justin.
I doubt there is much good to be done here, GeoServerExtensions is still an improvement on what was before.
Jody Garnett
On Tue, Apr 22, 2014 at 6:28 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Apr 22, 2014 at 10:24 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, I am having trouble figuring out the issue here, is there a pull request or patch to provide some context?
Is the problem that you don’t like doing this?
Why not just throw it in a test utility method and call it a day? Why do you have to modify GeoServerExtensions directly?
On Tue, Apr 22, 2014 at 2:33 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Jody Garnett
On Tue, Apr 22, 2014 at 10:24 AM, Jody Garnett <jody.garnett@anonymised.com..> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
You are correct that that is a workaround if you have an application context.
The key motivation is Kevin asking for for a way to quickly set GeoServerResourceLoader for test cases that want to look it up using GeoServerExtensions.bean(GeoServerResourceLoader.class).
I added GeoServerExtensions.init( name, bean ) to make writing these test cases easier.
Jody Garnett
On Tue, Apr 22, 2014 at 11:16 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 22, 2014 at 7:23 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
context.
cases easier.
Well my preference would be to not change the main api, and add a test
utility class that makes this easy. Also note that during the big test
change over last year we added some test utility classes to main to make
mocking up a GeoServer (and I am speaking true mocks here) easier. Look at
GeoServerMockTestSupport in org.geoserver.data.test. Perhaps you could put
what you need there.
Jody Garnett
Is the problem that you don't like doing this?
On Tue, Apr 22, 2014 at 2:33 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Justin.
Jody Garnett
applicationContext
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
@j_deolive <https://twitter.com/j_deolive&gt;
*Justin Deoliveira*
I have already looked - as part of trying to address Kevin’s feedback, I am trying to do this quickly to move on to my next pull request.
GeoServerMockTestSupport happens a little late for factories that use GeoServerExtensions during
We previously had some code using the GeoserverDataDirectory singleton to access a GeoServerResourceLoader. I have tried to move this to GeoSeverExtensions.
Still if you like I can make a GeoServerExtensionsUtil in the same package and use package visibility to get access to GeoServerExtensions internals (to edit the singleton cache).
Jody Garnett
On Tue, Apr 22, 2014 at 11:42 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Tue, Apr 22, 2014 at 7:23 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Well my preference would be to not change the main api, and add a test utility class that makes this easy. Also note that during the big test change over last year we added some test utility classes to main to make mocking up a GeoServer (and I am speaking true mocks here) easier. Look at GeoServerMockTestSupport in org.geoserver.data.test. Perhaps you could put what you need there.
Justin Deoliveira
@j_deolive
Jody Garnett
Justin Deoliveira
@j_deolive
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Apr 22, 2014 at 7:59 AM, Jody Garnett <jody.garnett@anonymised.com>wrote:
I have already looked - as part of trying to address Kevin's feedback, I
GeoSeverExtensions.
You're not being clear about the motivation here, or at least i can't infer
it from this conversation. Can you just point me at a specific test case
that Kevin has written.
Jody Garnett
context.
test cases easier.
Jody Garnett
from Justin.
Jody Garnett
applicationContext
well
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
*Justin Deoliveira*
*Justin Deoliveira*
infer it from this conversation. Can you just point me at a specific test
case that Kevin has written.
In the current codebase look for any/all examples of
GeoserverDataDirectory.setResourceLoader.
* MockCreator.createCatalog - this is the key gotcha that effects many test
cases
* DefaultGeoServerLoaderTest
* FileExistsValidatorTest
* PyCatalogModTest
Here is an example use from PyCatalogModTest.java:
Previously:
*GeoserverDataDirectory.setResourceLoader(scriptMgr.getDataDirectory().getResourceLoader());*
The replacement would be:
*GeoServerExtensions.init("resourceLoader",
scriptMgr.getDataDirectory().getResourceLoader() );*
This is due to code now using GeoServerExtensions (rather than
GeoserverDataDirectory) to look things up.
My suggestion on the pull request was just that the static calls to the GeoServerExtensions singleton might be a problem developing more unitary unit tests (I’d run into the same issue the day before) and it might be worth handling it in a way that made it easier to mock while we were changing things as long as it didn’t add to much work. I was thinking along the lines of just giving the classes protected/package getResourceLoader methods that could be overridden for the objects to be tested. A better way of doing this, or if there already is a way that hidden somewhere would be nice, but it’s not worth holding up the pull request for and I’ve no problem accepting it with the static calls in place.
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
In the current codebase look for any/all examples of GeoserverDataDirectory.setResourceLoader.
  • MockCreator.createCatalog - this is the key gotcha that effects many test cases
  • DefaultGeoServerLoaderTest
  • FileExistsValidatorTest
  • PyCatalogModTest
Previously:
GeoServerExtensions.init(“resourceLoader”, scriptMgr.getDataDirectory().getResourceLoader() );
This is due to code now using GeoServerExtensions (rather than GeoserverDataDirectory) to look things up.
You’re not being clear about the motivation here, or at least i can’t infer it from this conversation. Can you just point me at a specific test case that Kevin has written.
Thanks for the background Kevin, wish I had put this one off (or at least not tied it to the work I am doing). Note this approach is not specific to accessing GeoServerResourceLoader as we have several singletons.
I will move the static init methods to a separate testing GeoServerExtensionsSupport class so we have a way to accomplish what you would like - that does not add to the public API.
Jody Garnett
On 22 April 2014 07:17, Jody Garnett <jody.garnett@anonymised.com.403…> wrote:
Kevin Smith
+1-778-785-7459
@boundlessgeo
  • PyCatalogModTest
Previously:
On Tue, Apr 22, 2014 at 2:22 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Well if it's easier to throw them on GeoServerExtensions i am ok with
that... but cleaner imo would be a helper that makes it easy to mock up or
hack the application context directly and then just set that on
GeoServerExtensions. You're call.
Jody Garnett
unit tests (I'd run into the same issue the day before) and it might be
changing things as long as it didn't add to much work. I was thinking
hidden somewhere would be nice, but it's not worth holding up the pull
request for and I've no problem accepting it with the static calls in place.
test cases
* PyCatalogModTest
Previously:
Kevin Smith
+1-778-785-7459
@boundlessgeo <https://twitter.com/boundlessgeo&gt;
*Justin Deoliveira*
At the start of this conversation I offered the following example of using a mock application context:
replay(context);
The only part that is hard to understand is the anyObject → new String entry, basically saying “no” to any unknown singleton lookups.
If you can name a good place to put this boiler plate code I am fine with that.
Jody Garnett
On Wed, Apr 23, 2014 at 6:51 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Tue, Apr 22, 2014 at 2:22 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Well if it’s easier to throw them on GeoServerExtensions i am ok with that… but cleaner imo would be a helper that makes it easy to mock up or hack the application context directly and then just set that on GeoServerExtensions. You’re call.
Justin Deoliveira
@j_deolive
Jody Garnett
Kevin Smith
+1-778-785-7459
@boundlessgeo
  • PyCatalogModTest
Previously:
