[Geoserver-devel] [Geotools-devel] What does a filter with a null geometry attribute name mean?
Justin Deoliveira ha scritto:
I just ran up against this in my wfs 1.1 work. And the answer i got from
the wfs spec gods is that if the only filter that is allowed to not
specify an attribute name is BBOX. All other filters must specify an
property name.
The general policy in geoserver has been to be lenient with users, so
we usually accept partially broken requests without complaining afaik
(hope Chris does correct me if I'm wrong).
Note however that on trunk this is fixed. A "null" property name is
interpreted as being the default geometry.
So it does not really matter what the filter kind is, right?
property name.
That's definitely correct for general policy, but the code that uses a null geometry against things other than BBOX is kind of questionable, since I don't really know of any one that's needed it.
Though thinking back to the implementation things may work in some datastores. I don't think we need to spend a lot of effort try to support more than BBOX though, but if we don't then we should give good error messages.
Chris
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
!DSPAM:1003,45801764167756309890654!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
