[Geoserver-devel] GeoTools / GeoServer Meeting 2013-09-02
Attending
Andrea Aime
Ben Caradoc-Davies
Jody Garnett
Alessio Fabiani
Niels Charlier
Jukka Rahkonen
Agenda
* 2.4-RC2 release
* VFP module
* foss4g
2.4-RC2 release
1) (done) Set up cite tests
2) Get them to pass
3) much rejoicing
So stuck at point (2).
Examples of failures
WCS 1.0
http://hudson.opengeo.org/hudson/view/cite/job/2.4-cite-wcs-1.0/1/console
- failing on very basic stuff
- still some tests are passing?
- review shows pushd failing
http://hudson.opengeo.org/hudson/view/cite/job/cite-wcs-1.0-2.4/2/console
- working directory path problem?
- job naming convention perhaps? Testing via renaming
hudson build = 14
+ pushd /var/lib/hudson/cite/geoserver_data/2.4.x/citewcs-1.0
./run.sh: line 41: pushd: /var/lib/hudson/cite/geoserver_data/2.4.x/citewcs-1.0: No such file or directory
+ '[' -e init.sh ']'
+ popd
WFS CITE 1.0
http://hudson.opengeo.org/hudson/view/cite/job/2.4-cite-wfs-1.0/1/console
- wfs is failing on most things?
- looks like same problem as wfs
PULL REQUESTS
Q: Pull Requests? Is everything in...
A: Niels has one ...
1) csw improvement multi-value data
- geoserver pull request - andrea will merge on master so the build box tests
- geotools pull request -
- documentation updates
- request: every record is written by Niels! Look up geoserver administrator
2) freemarker? leave it on master to test stability
3) regression
- cannot remove web user interface
VFP module
Was never updated to GeoTools 2.5 feature model :slight_smile:
So it has not worked - and nobody noticed!
Well they did notice, jody reopened
foss4g
1) Code Sprint?
http://wiki.osgeo.org/wiki/FOSS4G_2013_Code_Sprint#GeoTools
- Frank is heading up translations, maybe consider making CSW translatable?
- Jody would like to stomp vecmath
2) BOF
http://wiki.osgeo.org/wiki/FOSS4G_2013_BirdsOfAFeather
Good idea - we should have one?
Notice a few on Friday and Saturday.
Of course Andrea is everywhere...
3) Crazy number of sessions - good luck finding everyone?
- Tuesday Evening - Ball game with LocationTech and OpenGeo types
Discussion
- LocationTech IP review, most questions answered 9.0-M1 branch should be ready for Sept 6th
- line offset discussion
- CSS i18n
- pull requests - some good stuff without email discussion
- ACTION: Justin to document build server on wiki (or similar)
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
