[Geoserver-devel] GeoTools / GeoServer Meeting 2014-04-29
Attending
Ben Caradoc-Davies
Jukka Rahkonen
Jody Garnett
Andrea Aime
Agenda
- previous meeting
- fonts and testing
- cite tests and build server
- Java 7
- Next Release
- filter/expression cleanup
- pull request round up / nagging
Actions:
- JG: Test Fonts on OSX
- JG: Pester GeoSever list to vote on Java 7 proposal
- BCD: Raise CITE tests on geoserver-devel mailing list
- AA: Email lists asking for a release volunteer (May 18th)
Previous Meeting
ACTIONS from last meeting:
- (done) Ben to follow up reported rendering failure on openjdk with Justin
- (done) All: Submit your foss4g presentation!
Fonts and Testing
Both java image diff and consistent font (LabelShieldTest) have arrived on master.
Jody will need to test on Mac (ie font metrics differences?)
Java 7
Ares has Oracle JDK7 - we can update configuration for master.. when proposals accepted?
CSIRO build box is using Oracle JDK6 and can be switched to OpenJDK 7.
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/
https://www.seegrid.csiro.au/wiki/Infosrvices/JenkinsGeoserverMaster
Ideally CSIRO could set up OpenJDK 7 so we can get a second opinon. And OSGeo Live would like that as well.
1) GeoTools "Upgrade master to Java 7" is approved
http://docs.codehaus.org/display/GEOTOOLS/Upgrade+master+to+Java+7
2) GeoServer proposal is not approved yet ...
http://geoserver.org/display/GEOS/GSIP+112+-+Upgrade+master+to+Java+7
Cite tests and build server
Justin/Andrea email discussion about CITE tests not working consistently/all the time. They are stating to be ignored ...
Is multithreaded builds being an issue -T2C ? Andrea builds this way all the time so that is probably not it.
Justin is the guy, Andrea has offered to help. Stay tunned?
Next Release (May 18th)
We need a volunteer GeoTools 11.1 / GeoServer 2.5.1 :slight_smile:
http://geoserver.org/display/GEOS/GeoTools+and+GeoServer+release+schedule
Filter/expression cleanup
It is finally happening ... technical debt since GeoTools 2.3
https://github.com/geotools/geotools/pull/434
GeoServer so far works with no change :slight_smile: Well one change to StreamingSVGMap that has already been applied.
Cumulative work, easy to review as it does one thing at a time.
However it may be easier to squash and review?
Andrea says leave it as it is.
Justin or Andrea should do this review?
Q: Is Kevin okay? This cannot be backported?
A: Kevin applied just the "equals" fix (ie use of getExpression1() and getExpression2()) and that was enough for his customer
Pull request round up / nagging
Q: A zillion pull requests are happening, anything that needs attention?
1) CQL fix - jody needs to apply feedback, and then merge to master.
2) Security configuration files showing up in wrong place / login configuration
https://github.com/geoserver/geoserver/pull/559
Jody says to check out the namespace.xml / workspace.xml file handling logic in GeoServerPersister.
- Code using new File( dir, path ) ended up in the wrong spot when dir was was not found (ie dir was null)
- Fix to FileUtils to allow it to copy directories was important.
Andrea is working on this.
3) fix jetty log versions dependency
https://github.com/geoserver/geoserver/pull/564
Caution with this on stable (as removing sf4l jar?)
Ben will comment on and close the 2.4.x pull request.
https://github.com/geoserver/geoserver/pull/563
4) Still waiting on contribution agreement for legend graphics :slight_smile:
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
