QGIS allows storing styles in PostGIS and GeoPackage.
Is it possible for GeoServer to read such styles - not currently.
Perhaps this could be implemented as a special “External SLD” URL
Action: Move to mailing list discussion.
**## 20.0/2.14.0/1.14.0 release timeline**
2.14.0 release currently scheduled for September (RC in August)
Last two fall releases have been delayed; looking at the release schedule, GT 14.0 / GS 2.8.0 was released 2015-09-23 (September). The next fall release, 2.10.0, was delayed until October, 2.12.x followed the same pattern, so the 2.14.0 release is us finally getting back on track.
**## Pull Request review**
GeoTools PR review; 9 PRs removed, several others awaiting feedback.
Hum… that would require a custom client though, one that knows the special URL and can figure out the right values.
Last time we discussed this it was at the GeoTools level, the outcome was to make these styles available as a part
of a *Info object attached to a FeatureSource right?
I’d suggest to go on this way, and then maybe add a counterpart in GeoServer, a NativeStyleInfo maybe, sub-interface
of StyleInfo, that does not only have a name, but also a reference to the store/source where the style comes from.
This would make it look like a normal style to most of the system, we’d just have to pay attention about removing
these styles when the source/store is gone (in the cascading delete machinery)
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I quite like that idea Andrea. One thing I have not heard addressed from any of these SLD in GeoPackage / PostGIS proposals is how to store icons? I guess it is limited to SE 1.1 encoding icons in the XML file.
Or linking to online (and stable) icons. Many products do it (MapBox, Google Earth).
