Attending
Torben Barsballe
Kevin Smith
Andrea Aime
Alessandro Parma
Jukka Rahkonen
Jan Boonen
Josh Fix
Actions from last meeting- [DONE] Jody: Draft AGM Update for GeoTools & GeoServer. Ian/Torben to review
- 2.15.3 Release in limbo → AA will do it after 2.16.0 - Thanks!
Agenda1. PSC Update
GeoServer Docker Images
GeoTools COG Datastore
2.16.0 Release
GSIP-176 Cite Test Activity
Actions- (done) agm-meeting slides for geotools and geoserver
PSC Update
Brad has stepped, thanks for your service.
Discussion on PSC representation:
Desire for more user representation, do not see any active users to nominate
Nuno is an active developer
discussion of balance, with so many GeoSolutions active we can get a lot of +0/-0 in case a proposal is coming from GeoSolutions itself
GeoServer Docker Container
Some requests last year, follow up to foss4g discussion:
Request on geoserver devel about this earlier in 2019
Kartoza docker image very popular and is often the key way developers access
List of images:
vector tiles, control-flow, monitoring, …
vector tiles, csw, control flow, jpegturbo, jdbcconfig, gdal, excel, charts
monitor, status monitoring, control flow, jpegTurbo, …
Q: Discussion on how to handle extensions:
Option: environment variables to control installing of extension
see setup.sh example to download at build time
discussion: could download build time, and install at run time
Option: tagged builds with different profiles
consider minimal, …
Q: Data directory - how to handle?
Use of default or minimal default
JDBCConfig + JDBCStore (this is very much a community module) → Jan is thinking to start working on these modules
Option: transient inside container
Option: externalize file system, data directory, tilecache etc..
Q: Scope
Developer plaything for testing? Like windows installer
(that is still often used for production…) -
Production image? Seems the case from control-flow, monitoring, …
Aside: discussion on control-flow configuration settings
Aside: discussion of PostGIS container automatically configuring, see: https://pgtune.leopard.in.ua/#/
Security scan is possible with some image repositories, e.g.
Configuration options:
Ubuntu baseline
JNDI - one has optional JNDI for PostGIS (https://github.com/boonen/docker-geoserver/blob/master/assets/confd/templates/context.xml.tmpl#L35)
CORS - or reverse proxy in front of GeoServer or https://github.com/kartoza/docker-geoserver#build-with-cors-support
Tomcat Version
Java Version: Did a test and it worked quite well to support multiple java versions
How to start this?
Repository
Start at github.com/geoserver/docker ← (done) jody to setup repository and team
Start at hub.docker.com/u/geoserver/geoserver ← contains prebuilt images
Needs to set up organization
Approach
Start from scratch?
Start from one that is close …
Release process?
Start off manually
We really want this done at build.geoserver.org at the end of the day
Is it just an environment variable? To download latest versions…
Nightly build? “nightly-master” “nightly-stable” “nightly-maintenance”
Version: “2.14-nightly”, .. -
Development stream: “stable” ,”maintenance”
Release series: “2.15”, “2.14”, …
COG reader
Pure java implementation, doing range requests, caching optional, more info here:
https://github.com/joshfix/cog-image-reader
Base class extending imageio-ext TiffImageReader
A couple classes are copied wholesale with a few modifications due to visibility restrictions (private / final) in the code
Is this going to be a problem with license? - ImageIO-ext is LGPLv3, ImageIO is (mostly) BSD.
Can we just modify the classes in question to relax these restrictions - yes, as long as it is in imageio-ext
Configuration
Can mostly be done via coverage parameters in GT/GS
How to configure caching parameters?
Environment variables for now, to get this moving along
COG Reader SPI
- Make two SPIs? One for caching and one not?
Implementations:
Pure java - HTTP vs S3 vs Azure
Azure uses some wasb URLs containing auth/bucket information that is incompatible with pure HTTP
GDAL-based COG - has some nodata issues around mosaicing…
Next step: Add as plugin to imageio-exts
Add tests
Swap System.out to logging
Start with pure-java, maybe add GDAL later
2.16.0 Release
Currently in progress
Ran out of time to discuss, move to mailing lists
