Attending- ### Torben Barsballe
Jody Garnett
Kevin Smith
Jukka Rahkonnen
Robert Zych
Andrea Aime
Actions from prior meetings:- N/A
Agenda- mkdocs_translate on pypi
GeoServer 2.24.3 / GeoTools 30.3 release manager
Apache Pinot compatibility
Make GWC FileBlobStore not blow up on many filter parameters
pr check-in
chit chat
Actions- Andrea: send an email for the release manager
Jody: Reach out to Jo Cook (Astun) regarding core contributor status
Jody: Propose adjustments to contributor policy requiring interaction on an individual (not organization) level
Improved install instructions
need a “writable python environment” to install script; not sure why? Perhaps some dependency thing …
Easy install from pypi: https://pypi.org/project/mkdocs-translate/0.4.0/
still have not troubleshot script getting confused over code-block boundaries; due to :ref:`something
turning intosomething```` (looks like a markdown code-block) -
jody thanks everyone for testing / encouragement
Jody has a blocker to fix:
Performance regression due to BigInteger replacement
AtomicLong cache = new AtomicLong(Long.MIN_VALUE);
return () → {
try {
if (cache.get() == Long.MIN_VALUE) {
long total = getTotalCount(totalCountExecutors);
cache.set(total);
return BigInteger.valueOf(cache.get());
} catch (IOException ioException) {
throw new RuntimeException(
"Lazy total count unavailable " + ioException.getMessage(),
ioException);
Apache Pinot compatibility- https://pinot.apache.org
Real time OLAP datastore
Has a few ST_ functions
See also: this issue: https://github.com/apache/pinot/issues/12805
PostgreGIS references a few others…
Developments Notes:
JDBCDataStore framework handles simple SQL text / number
Customize the “Dialect” to teach it how you do geometry
And what functions you have …
Recommend looking at MySQL as an example of a simple DataStore
(that does not use ST_ functions)
https://github.com/GeoWebCache/geowebcache/pull/1230
avoid using a single file to store all the combinations
documentation change? should be transparent
backwards compatible (will try the new name, and if not found it will read the single property file)
PR Check-in
Review https://github.com/geoserver/geoserver/pulls
Review https://github.com/geotools/geotools/pulls
