I'm testing out the use of one ecw for an aerial instead of a directory
of geotiffs.
While with the geotiffs it was possible to ask for a tile which is
fully(!) outside of the data extent, with an ecw (gdal extension) I get
the following error (both in 2.6 as in 2.8)
Error rendering coverage on the fast path java.lang.NullPointerException
Looking into the stacktrace, it is maybe something with generating a
colormap which has off course no data there?
Should I create an issue (I'm not able to attache a small ecw though)?
Or is there something I can configure to prevend this?
Below the full error and stacktrace
Richard Duivenvoorde
ps the reason we request tiles outside the data is because the layer is
part of a much bigger layer
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://gng-ap713.nieuwegein.nl/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
</ServiceException></ServiceExceptionReport>
2015-10-05 13:51:32,878 DEBUG [org.geotools.coverageio.gdal.ecw] -
Creating a new ECWFormat.
2015-10-05 13:51:32,879 TRACE [org.geotools.factory] - ENTRY
(GridCoverageFactory)
2015-10-05 13:51:32,879 TRACE [org.geotools.factory] - RETURN
(GridCoverageFactory): found implementation GridCoverageFactory.
2015-10-05 13:51:32,880 DEBUG
[org.geotools.renderer.lite.gridcoverage2d] - Rendering using
interpolation javax.media.jai.InterpolationNearest@anonymised.com
2015-10-05 13:51:32,881 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the
fast path
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:345)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:260)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:132)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:504)
at org.geoserver.wms.GetMap.run(GetMap.java:248)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor272.invoke(Unknown Source)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:319)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at
org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at
org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at
org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at
org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at
at
org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at
at
org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at com.sun.proxy.$Proxy74.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor182.invoke(Unknown Source)
at
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:845)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:275)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
at
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
at
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:503)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at
org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:421)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2462)
at
org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2451)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException:
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1054)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:343)
... 118 more
Caused by: java.lang.NullPointerException
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:818)
at
org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:767)
at
org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:947)
... 119 more
Dear Richard,
which specific version of GS did you use to produce that log, so we can track the problem?
(A 2.8 nightly build? a 2.8.0? …?)
(Asking this because the reported NPE seems coming from a recent line of code which by the way is not part of 2.6.x).
I’m testing out the use of one ecw for an aerial instead of a directory
of geotiffs.
Should I create an issue (I’m not able to attache a small ecw though)?
fast path
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 118 more
at
at
at
… 119 more
Dear Richard,
track the problem?
(A 2.8 nightly build? a 2.8.0? ...?)
The log is from a just installed 2.8.0
But I've received the same xml error back when that server was still on
2.6.x
But the stacktrace is from 2.8.0 probably with geotools development
logging...
Dear Richard,
track the problem?
But I’ve received the same xml error back when that server was still on
2.6.x
logging…
