[Geoserver-devel] Gs2.5.2 ImageMosaic layers show totally white image for version=1.3.0 even if bbox values swapped. Related to GEOS-6651.
Hi Ville,
White map is not an error, BBOX just does not find any data. With these parameters you will see something.
REQUEST=GetMap&
SERVICE=WMS&
VERSION=1.1.1&
WIDTH=459&
HEIGHT=346&
LAYERS=vantaa_vrad&
TRANSPARENT=TRUE&
FORMAT=image%2Fpng&
BBOX=217793.48568830438,6559579.00279505,546456.0579426396,6807329.00279505&
SRS=EPSG:3067&
STYLES=
There is a slight error in 1.3.0 example because not only axis are sometimes flipped in WMS 1.3.0, also what used to be SRS is now CRS because there must be something fundamentally wrong with SRS. But I believe that this was a copy-paste error.
However, I believe that we have found now something that is really interesting. Your layers which work OK with WMS 1.1.1 give this error with valid 1.3.0 requests:
Error rendering coverage on the fast path
org.opengis.geometry.MismatchedReferenceSystemException: The coordinate reference system must be the same for all objects.
Objects are the same for WMS 1.1.1 and 1.3.0 but only latter finds some of them problematic.
I have no idea where the error comes but it is not anything built-in. Geoserver does work with WMS 1.3.0 in EPSG:3067. You can test it even with top:states
http://demo.opengeo.org/geoserver/wms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.3.0&WIDTH=459&HEIGHT=346&LAYERS=topp%3Astates&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-4.1951248737102486E7,-1.7460255973785944E7,6.963191131485114E7,6.6652540056662746E7&CRS=EPSG:3067&STYLES=
-Jukka-
Ville Karppinen wrote:
Thank you really much Andrea and Jukka for your quick answers.
I am still wondering, why is it so that I can not get a proper image when using EPSG:3067 even if I try bbox in both ways. If I swap the value, I get white image. If I do not swap, I get the error XML.
So, does it require that I need to use totally different SRS?
White:
http://wms.fmi.fi/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/Radar/wms?LAYERS=Radar%3Asuomi_rr_eureffin&STYLES=&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&SRS=EPSG%3A3067&BBOX=6335621.1670142,-117278.40864788,7907751.5372634,874514.7741461&WIDTH=323&HEIGHT=512
Error:
http://wms.fmi.fi/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/Radar/wms?LAYERS=Radar%3Asuomi_rr_eureffin&STYLES=&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&SRS=EPSG%3A3067&BBOX=-117278.40864788,6335621.1670142,874514.7741461,7907751.5372634&WIDTH=323&HEIGHT=512
Best regards,
Ville Karppinen
[ville.karppinen@...3920...](mailto:ville.karppinen@...3920...)
+358407509542
On 09/24/2014 01:22 PM, Rahkonen Jukka (Tike) wrote:
I had not noticed before that EPSG folks are trolling with the official remarks as in
http://www.epsg-registry.org/indicio/query?request=GetRepositoryItem&id=urn:ogc:def:crs:EPSG::3067
gml:remarksIdentical to ETRS89 / UTM zone 35N (code 25835) except for area of use.
See ETRS89 / TM35FIN(N,E) (code 5048) for more usually used alternative with
axis order reversed.</gml:remarks>
Nobody uses EPSG:5048 in Finland as far as I know.
-Jukka Rahkonen-
Andrea Aime wrote:
On Wed, Sep 24, 2014 at 11:58 AM, Ville Karppinen <ville.karppinen@…3920…> wrote:
My question is related to the issue https://jira.codehaus.org/browse/GEOS-6651 which ended up to be a user error related to the bbox value. It seems that when version 1.3.0 bbox coordinates are swapped, only some of the images are shown properly. This seems to depend on the srs-value. For example in our services, &srs=EPSG:3035 shows images properly but when using &srs=EPSG:3067 images become totally white.
Yes, WMS 1.3 requires swapped coordinates only if the SRS in question uses
north/east orientation in the official EPSG database, you can check its online
version here: http://www.epsg-registry.org/
As a simplified rule, most of the geographic CRS need to use lat/lon order,
most of the projected ones are east/north instead (although there are a few exceptions
of projected SRS that still use north/east order)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
A summary based on previous comments to give a clear idea of this issue:
Some layers which work OK with WMS 1.1.1 give an error with valid 1.3.0 requests.
EPSG:3067 is easting-northing system so there is no need to flip the axis for 1.3.0 bbox.
Version 1.1.0 gives an image:
http://wms.fmi.fi/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/Radar/wms?LAYERS=Radar%3Asuomi_rr_eureffin&STYLES=&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A3067&BBOX=-117278.40864788,6335621.1670142,874514.7741461,7907751.5372634&WIDTH=323&HEIGHT=512
Version 1.3.0 gives an error, even if an image is expected (no need to flip bbox, using CRS instead of SRS in URL):
http://wms.fmi.fi/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/Radar/wms?LAYERS=Radar%3Asuomi_rr_eureffin&STYLES=&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG%3A3067&BBOX=-117278.40864788,6335621.1670142,874514.7741461,7907751.5372634&WIDTH=323&HEIGHT=512
1.3.0 error:
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://wms.fmi.fi:80/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd&quot;&gt;
<ServiceException>
Error rendering coverage on the fast path org.opengis.geometry.MismatchedReferenceSystemException: The coordinate reference system must be the same for all objects. The coordinate reference system must be the same for all objects.
</ServiceException>
</ServiceExceptionReport>
Best regards,
Ville Karppinen
ville.karppinen@anonymised.com
+358407509542
On Wed, Sep 24, 2014 at 2:02 PM, Ville Karppinen <ville.karppinen@anonymised.com.>
1.3.0 error:
<ServiceException>
</ServiceException>
Do you have the full stack trace?
Also, any chance you can share a (small) dataset that can be used to
reproduce the issue you're seeing?
Ing. Andrea Aime
@geowolf
Technical Lead
