Proposal ready for GeoServer:
http://geoserver.org/display/GEOS/GSIP+112±+Upgrade+to+Java+7
On Wed, Apr 9, 2014 at 6:55 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
http://geoserver.org/display/GEOS/GSIP+112+-+Upgrade+to+Java+7
Currently the GeoServer build fails on a WPS process test:
Tests in error:
testRangeLookup(org.geoserver.wps.gs.RangeLookupTest):
org.geotools.data.DataSourceException: Unable to parse the header for the
provided input
I've tried to figure out what is going on already in the last few months
during spare time, but so far, could not
an answer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I was unable to reproduce this failure using: mvn clean install -Prelease
Environment: Oracle JDK 1.7.0_51
Is this failure specific to OpenJDK ?
Tests in error:
provided inputI've tried to figure out what is going on already in the last few months
an answerCheers
Andrea--
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
On Fri, Apr 11, 2014 at 4:12 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
No, for me it fails with both Oracle JDK 1.7.0_51 and OpenJDK 1.7.0_51
(and I've seen the same failure on Travis in the past, too)
Ing. Andrea Aime
@geowolf
Technical Lead
Runs from eclipse as well, … note this is one of the tests that generates several pages out system out content.
Jody Garnett
On Sat, Apr 12, 2014 at 12:15 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Apr 11, 2014 at 4:12 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
(and I’ve seen the same failure on Travis in the past, too)
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Apr 11, 2014 at 4:31 PM, Jody Garnett <jody.garnett@anonymised.com>wrote:
Runs from eclipse as well, .. note this is one of the tests that generates
Fails from eclipse with both jdks for me
Ing. Andrea Aime
@geowolf
Technical Lead
Considering that at least one person has “it works on my machine”, I would have to ask the question “What is different about the environments?” Could it be difference in OS, permissions? Development IDE?
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Direct (719) 452-7257
On Fri, Apr 11, 2014 at 4:31 PM, Jody Garnett <jody.garnett@anonymised.com03…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Apr 11, 2014 at 4:40 PM, Chris Snider <chris.snider@anonymised.com>wrote:
Considering that at least one person has "it works on my machine", I
would have to ask the question "What is different about the environments?"
In my case it's failing in both maven and the IDE, so it's not likely to be
Eclipse, but I use Eclipse Kepler SR1
The rest is Ubuntu 12.04, 64 bit, and the above mentioned JDK versions.
I work in my home folder, so I have full permissions
My hunch is that it's file system iteration order, we are probably getting
the imageio/coverage readers
iterate in a different way (believe there is nothing we can do to make that
order predictable)
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea, I have created a Jira issue http://jira.codehaus.org/browse/GEOS-6448 so we can track this a bit more formally.
I would like to see if the issue is limited to linux or if it can be reproduced on windows as well.
Jody Garnett
On Sat, Apr 12, 2014 at 12:43 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Apr 11, 2014 at 4:40 PM, Chris Snider <chris.snider@anonymised.com> wrote:
In my case it’s failing in both maven and the IDE, so it’s not likely to be Eclipse, but I use Eclipse Kepler SR1
My hunch is that it’s file system iteration order, we are probably getting the imageio/coverage readers
iterate in a different way (believe there is nothing we can do to make that order predictable)
Ing. Andrea Aime
@geowolf
Technical Lead
Found the problem and fixed it: http://jira.codehaus.org/browse/GEOT-4769
On Sat, Apr 12, 2014 at 6:11 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
On Fri, Apr 11, 2014 at 4:40 PM, Chris Snider <chris.snider@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks, I put in a request to boundless IT it configure OpenJDK 7 on ares.
So if we can ask people to vote on both proposals we should be good to go … next week?
Jody Garnett
On Sat, Apr 12, 2014 at 10:38 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Added my +1 to the proposal
Christian
On Sat, Apr 12, 2014 at 3:05 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Put Bad Developers to Shame
Dominate Development with Jenkins Continuous Integration
Continuously Automate Build, Test & Deployment
Start a new project now. Try Jenkins in the cloud.
http://p.sf.net/sfu/13600_Cloudbees
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
I just tried changing over the geotools master build to an openjdk 7 jdk but there are rendering failures. An oracle jdk 7 vm works fine though. Going with oracle for now until told otherwise.
On Sat, Apr 12, 2014 at 7:05 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
