[Geoserver-devel] GSIP 120, REST API for access control
https://github.com/geoserver/geoserver/wiki/GSIP-120-REST-API-for-access-control
Please comment and vote.
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
+1 and thanks for the clear proposal.
Tip: remember to leave time/budget for docs :slight_smile:
Jody Garnett
On Fri, Oct 17, 2014 at 8:04 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-devel mailing list
Thanks Chrisitan. A couple of points.
In the interest of keeping urls relatively short, can we shorten the api path to “/security/acl” or “/security/access”? Other may not like that… up for debate.
Second is regarding update via PUT. Will the user be able to update individual rules? Or will they have to PUT all access rules (including the changed ones)?
On Fri, Oct 17, 2014 at 1:10 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
Jody Garnett
Hi Justin
I modified the GSIP.
  1. The API path is /security/acl
  2. I added the sentence “The request body contains the modified rules” to the description of the PUT method.
Christian
On Fri, Oct 17, 2014 at 11:24 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
@boundlessgeo
Jody Garnett
Hi Christian,
in the proposal I don’t see the fine grained access to rules that was discussed
with Mauro?
How do you delete just a single rule?
On Fri, Oct 17, 2014 at 5:04 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ciao Christian,
I was about to ask a question similar to andrea’s one.
This approach is fine and I don’t want to waste your time on this as you h ave funding available, but the concerns expressed by Mauro (http://osgeo-org.1560.x6.nabble.com/REST-API-for-access-control-td5166448.html) are not (entirely?) addressed:
-1- the proposal is tied to properties files format
-2- granularity is quite coarse with respect to rules management
Simone Giannecchini
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Sat, Oct 18, 2014 at 11:29 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Christian,
with Mauro?
Ing. Andrea Aime
@geowolf
Technical Lead
Hi
About granularity, the PUT,DELETE and POST method work with a set of rules. This does not mean all rules, the set may contain only one rule.
About the XML property file format, I will change this. There is a class MapResource in the rest-config module, I think I will reuse this code.
But I found another problem. The original property files have a nice comment describing the syntax. After rewriting the file, the comment is gone. There is no method in the Java Properties class to read a comment. Should I open a thread for this topic ?
Christian
On Sat, Oct 18, 2014 at 12:39 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Christian,
Simone Giannecchini
@simogeo
Founder/Director
Hi Christian,
with Mauro?
On Fri, Oct 17, 2014 at 5:04 PM, Christian Mueller <christian.mueller@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Oct 18, 2014 at 1:32 PM, Christian Mueller <
Hi
Could you make an example? Normall in REST when you issue a delete against
a resource, the whole resource is deleted.
Having a delete that only partially deletes the content of a resource would
be odd at least.
http://www.restapitutorial.com/lessons/httpmethods.html (see DELETE)
I guess you could represent the rules as having also a comment, but as you
said, you'll have to roll your own reader/writer
for the file contents, one that assumes a comment before a rule is
associated to that rule.
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
Thanks to the hint about the DELETE method. I think it is not forbidden to add a request body to a delete request, but I seems to be a bad practice.
http://www.spenceruresk.com/2011/11/http-delete-requests-that-include-a-body/
Maybe we can encode the rule keys as a comma separated list using an URL parameter.
/security/acl/layers?rules=..r,..w
On Sat, Oct 18, 2014 at 2:20 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Oct 18, 2014 at 1:32 PM, Christian Mueller <christian.mueller@anonymised.com…> wrote:
Hi
Could you make an example? Normall in REST when you issue a delete against a resource, the whole resource is deleted.
Having a delete that only partially deletes the content of a resource would be odd at least.
I guess you could represent the rules as having also a comment, but as you said, you’ll have to roll your own reader/writer
for the file contents, one that assumes a comment before a rule is associated to that rule.
Ing. Andrea Aime
@geowolf
Technical Lead
On Sat, Oct 18, 2014 at 2:44 PM, Christian Mueller <
Hi Andrea
parameter.
/security/acl/layers?rules=*.*.r,*.*.w
Hum could be, but I think I'd associate some sort of identifier to the
rules, and use that instead,
and would still expose resources like /security/acl/layers/1,
/security/acl/layers/2 that you
can issue a DELETE against, yes it's chatty, but it's also the idiomatic
way in REST services
Ing. Andrea Aime
@geowolf
Technical Lead
Hmm
A simple numbering system is dangerous. Between the GET and the DELETE rules may have been added. Deleting the wrong rule may be a consequence. Using a MD5 check sum would be a solution, like
/security/acl/layers/7AC93B1A17731D9EA925EB13C0CF3BCC
This is the md5 sum for ..r
I hope to get some additional input from Justin.
Christian
On Sat, Oct 18, 2014 at 4:00 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Oct 18, 2014 at 2:44 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Andrea
Hum could be, but I think I’d associate some sort of identifier to the rules, and use that instead,
and would still expose resources like /security/acl/layers/1, /security/acl/layers/2 that you
can issue a DELETE against, yes it’s chatty, but it’s also the idiomatic way in REST services
Ing. Andrea Aime
@geowolf
Technical Lead
This is the md5 sum for *.*.r
That is pretty ugly. Why not just an escaped version of the key?
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Hi Phil
The rest.properties file has a key
Not sure if
/security/acl/layers//**
will work.
On Sun, Oct 19, 2014 at 10:17 PM, Phil Scadden <p.scadden@anonymised.com> wrote:
On Mon, Oct 20, 2014 at 12:10 PM, Christian Mueller <
Hi Phil
Not sure if
will work.
It may if you url-escape it:
%/security/acl/layers/2F**
Ing. Andrea Aime
@geowolf
Technical Lead
If the identifier is going to show up and be used in urls I like the idea of using the md5sum or some other generated identifier. They are long but easier to use than strings that require url encoding. But it feels like a bad idea to generate ID’s for rules at the level of the rest api. Seems what is really needed is that the rules themselves store an identifier. But that will be a problem without any way to persist them. So yeah, guess the url-encoded key from the properties seems like the best bet.
On Mon, Oct 20, 2014 at 4:25 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Justin Deoliveira
@boundlessgeo
On Mon, Oct 20, 2014 at 12:10 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Could the identifier be something generated by the user? Such as /security/acl/All%20User%20Read/..r
Using a generated identifier is good when something isn’t already identified, but it would be nice to have the ability to set my own identifier that has user meaning.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
(attachments)
On Mon, Oct 20, 2014 at 4:25 AM, Andrea Aime <andrea.aime@…1268…> wrote:
On Mon, Oct 20, 2014 at 12:10 PM, Christian Mueller <christian.mueller@…3674…> wrote:
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
jdeolive@…3839…
@boundlessgeo
Uppps
Things become complicated. For HTTP DELETE, I will investigate in the URL encoded version of the access rule key.
Christian
(attachments)
On Mon, Oct 20, 2014 at 3:14 PM, Chris Snider <chris.snider@anonymised.com5…> wrote:
Chris Snider
Description: Description: Description: cid:image001.png@anonymised.com
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Monday, October 20, 2014 6:35 AM
To: Andrea Aime
Cc: geoserver-devel
Subject: Re: [Geoserver-devel] GSIP 120, REST API for access control
On Mon, Oct 20, 2014 at 4:25 AM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
@boundlessgeo
About the GET operation, would be feasible to add also the pagination through some query parameters?
(attachments)
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
On Mon, Oct 20, 2014 at 4:04 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Uppps
Christian
On Mon, Oct 20, 2014 at 3:14 PM, Chris Snider <chris.snider@anonymised.com> wrote:
Chris Snider
To: Andrea Aime
Cc: geoserver-devel
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
@boundlessgeo
Hi Alessio
I hope you can modify the GSIP. If you can, please bring in your ideas.
Christian
(attachments)
On Mon, Oct 20, 2014 at 4:18 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
@alfa7691
Uppps
Christian
Chris Snider
To: Andrea Aime
Cc: geoserver-devel
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
@boundlessgeo
Hi all
I changed the XML format to be independent of the Java XML properties format. Further I did some minor changes in the HTTP return codes. All changes can be reviewed in the GSIP.
The DELETE request is still under investigation.
Christian
(attachments)
On Mon, Oct 20, 2014 at 4:13 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Alessio
Christian
@alfa7691
Uppps
Christian
Chris Snider
To: Andrea Aime
Cc: geoserver-devel
Hi Phil
Not sure if
will work.
Ing. Andrea Aime
@geowolf
Technical Lead
Justin Deoliveira
@boundlessgeo
