[Geoserver-devel] GSIP-126 - Runtime ProcessParameterIO creation
here is a proposal for the 2.8.x series:
https://github.com/geoserver/geoserver/wiki/GSIP-126—Runtime-ProcessParameterIO-creation
The proposal implementation will be quite simple and non invasive, so we’ll want to propose
a backport to the 2.7.x series once the dust settles around the 2.7.0 release.
In fact, I was not sure whether to write a proposal at all, but Jody recently observed that he’d
like to see proposals for new extension points, no matter how small/peripheral they are,
so here it is :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It is okay Andrea, it was just a question about proposal for new extension points (since I have not been in day to day geoserver for a while). If we can handle it via email that is fine :slight_smile:
On 21 January 2015 at 01:47, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Geoserver-devel mailing list
Jody Garnett
On Wed, Jan 21, 2015 at 6:50 PM, Jody Garnett <jody.garnett@anonymised.com>
Cool, either work for me.
If anyone has feedback, just let me know
Cheres
Ing. Andrea Aime
@geowolf
Technical Lead
As for the proposal I like it, any chance of this interface living in GeoTools level? Not that I will ever get WPS client funding…
Alternate suggestion is to split this up into a read interface and a write interface (with the same method names) - and then use those as marker interfaces.
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
On Wed, Jan 21, 2015 at 7:09 PM, Jody Garnett <jody.garnett@anonymised.com>
GeoTools level? Not that I will ever get WPS client funding...
I don't see it happening without funding... unless someone decides to crush
a good number of weekends on it.
interfaces.
Though about it, but it would break solid all existing PPIOs around, I know
there is a number of custom ones out there,
basically anyone that has wrote a process with some new input or output
objects had to write ont
Ing. Andrea Aime
@geowolf
Technical Lead
+0 from me. I dont think I can comment usefully on this detail and user implications seem a little remote.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Yeah thanks for the feedback, I will keep wps-client as an unfunded dream.
No problem with the api change, added +1 to the page.
On 21 January 2015 at 10:12, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Wed, Jan 21, 2015 at 7:09 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I don’t see it happening without funding… unless someone decides to crush a good number of weekends on it.
Though about it, but it would break solid all existing PPIOs around, I know there is a number of custom ones out there,
basically anyone that has wrote a process with some new input or output objects had to write ont
Ing. Andrea Aime
@geowolf
Technical Lead
if anybody is interested in reviewing, the work is done and the pull request is here:
https://github.com/geoserver/geoserver/pull/936
The changes to WPS are minimal, the old extension/ogr has become extension/ogr/ogr-wfs
and there is a new extension/ogr/ogr-wps that uses the same code as wfs to generate
encode only PPIOs
On Wed, Jan 21, 2015 at 10:47 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
