I think managing the docker builds in the “build” directory is appropriate. Is it worth co-locating these with their cite data directory configuration (to make each folder more self contained)?
aside: In the past when faced with builds grabbing status codes we would grep through the output for failure, not sure how stable that is.
There is not an official repository on docker hub for this, we should set this up (I am not sure what is needed).
HI Jody, All,
Status update with a couple of questions about the source code management and deployment of this work:
I added more builds for the ets suites, updated list:
wms11
wms13
wfs10
wfs11
wcs10
wcs11
wcs20
wfs20
Then created a build for the teamengine-docker fork to build the docker image for teamengine with the suites and tools that we need.
The docker image includes all of the sutes that we use and a single docker images can be used by all cite test runs (there is
nothing test-specific in it). This build is currently hosted on this build server because I had some issues with the build on geoserver
build server that I still need to address… The docker image is currently pushed here on the docker hub (more on this later)
I then created a parameterized build to run the tests. It is currently building from my GeoServer fork where I pushed the docker-compose files
and the other auxiliary files required to run the tests. My idea, and I’d like to have feedback from you as well as from the GeoServer
ML, is to add all the files required into the ‘build’ subdirectory of the repository. Would this be ok?
The file structure mimics that in our proposal where we have a global docker-compose.yml file with a ‘geoserver’ and '‘teamengine’ service
definition and subdirectory for every test suite with test specific files like “forms” for command line execution of a given test suite and a
docker-compose override file to spin up postgresql if required by the specific test. For data directories I’d use the ones that are
already available in the repository.
An example execution of this parametrized build is available here where I ran the WMS 1.1.1 suite against the latest geoserver master nightly.
The log files from the test run are stored as artifacts from the job run. There is still some work to do, notably, the job does not fail when a given
test fails (apparently due to the test.sh script in the teamengine suite swallowing the status of the tests. I still need to figure this out) and to add
more builds for the other suites. I’ll keep you informed on my progress on this.
Concerning the docker image(s) for teamengine-docker is there an official repository for GeoServer on the docker hub where I can push the image?
Thank you in advance for your feedback,
Alessandro
On Fri, Feb 21, 2020 at 6:00 PM Alessandro Parma <alessandro.parma@anonymised.com…> wrote:
Dear Jody, All
Just a quick update on this:
I set up a test build on the build server for one of the CITE tests to build and deploy the artifacts on the maven repository and
I am currently working on the the docker images and writing the docker-compose file to run the geoserver, postgres and teamengine
containers to execute the tests.
The build job is taking the Github branch and tags as parameters (with defaults) and is not tightly bound to the build environment so It
would be pretty straightforward to migrate it to another build server.
For the docker images and I don’t have something ready to show yet, I’ll let you know as soon as I do.
On Fri, Feb 14, 2020 at 6:42 PM Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Hi Jody,
We are a little beyond schedule with this, the work has started but there is little to show.
We will send periodic updates to the psc and devel list starting next week.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Thu, Feb 13, 2020 at 6:08 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Simone:
Next week’s Feb 18th meeting is our final meeting in February, is there any update from the Cite Automation work?
With the recent news from Planet Federal I am concerned about ability to deliver into build.geoserver.org environment.
Jody Garnett
Simone Giannecchini.
GeoSolutions Director
- sent from my mobile, apologies for brevity and typos-
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Alessandro Parma
Alessandro Parma
DevOps Engineer
