If this proposal is ready for the 2.22.0 release it would simplify the process of setting up build jobs for the new release cycle. Vote early, vote often…
[GEOS-10638] drop Java 8 support from docs (details)
Remove java 8 reference from developers guide (details)
Commit 6fdd602bcb3cffc66f80f22ef3c93b2a84a3c606 by Jody Garnett
The file was modified doc/en/user/source/configuration/status.rst (diff)
The file was modified doc/en/user/source/production/java.rst (diff)
The file was modified doc/en/user/source/security/passwd.rst (diff)
The file was modified doc/en/user/source/installation/index.rst (diff)
The file was modified doc/en/user/source/installation/war.rst (diff)
The file was modified doc/en/user/source/installation/win_binary.rst (diff)
The file was modified doc/en/user/source/installation/win_installer.rst (diff)
The file was modified doc/en/user/source/installation/linux.rst (diff)
The file was modified doc/en/user/source/production/container.rst (diff)
Commit 21fa400de4fb43fd8c26dda8dd4f18f45b98d4fc by Jody Garnett
The file was modified doc/en/developer/source/tools.rst (diff)
The file was modified doc/en/developer/source/qa-guide/index.rst (diff)
I am not sure what to make of it; and do not wish to revert; or force push; without a better understanding of what is going on.
That looks to be a merge of geoserver:main into euanmitchell:main (the source of the PR). I assume that remote was rather behind geoserver:main at the time of the merge, which would explain the large number of changes for that commit, and the relatively few number of actual changes relative to geoserver:main
