To wake up this thread, I would like to also delay the 2.10-RC until this issue is resolved.
On 28 September 2016 at 07:30, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Devon,
if you have time that would certainly be most appreciated.
At the moment the 2.9.x build has been red for a while and as a result we don’t have
a build with the latest fixes in. The latest failure is really odd, it’s like a file got stolen
away from GeoServer during the build… let’s see if it’s repeatable (the build was working
fine on my machine), if it gets green I’ll try to kick the nightly and then the CITE tests
GeoTools-Devel mailing list
GeoTools-Devel@anonymised.com66…sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Jody Garnett
On Wed, Sep 28, 2016 at 2:05 AM, Devon Tucker <devonrtucker@anonymised.com…403…> wrote:
I have time to do the 2.9.2 release if it would help out.
Devon
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Wed, Sep 21, 2016 at 12:31 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
sad news, the blocker from yesterday was solved, but I found a new one (cannot update stores, GeoServer complains the store
already exists) and realszed that the XEE vulnerability reported on WMS cascading has not yet been solved.
Until both are fixed we won’t be able to release 2.9.2.
I have someone working on the store saving issue, but no one at the moment on the XEE one. Discussion about it on the geotools-devel list is ongoing.
GeoTools-Devel@anonymised.comge.net
On Tue, Sep 20, 2016 at 11:38 AM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
we have found out a bug caused by a backport on 2.9.x happened after the 2.9.1
release that occasionally causes the GWC cached layers configuration to be wiped out.
We are working on a fix:
https://osgeo-org.atlassian.net/browse/GEOS-7750
The bug per se make the loading of a GWC layer fail, and the GWC integration just deletes the cached layers it cannot load,
not 100% sure this is a good behavior but it makes some sense in a clustered environment I guess.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
