[Geoserver-devel] GWC and @override vs deploying recent jars - method nativeAccelAvailable
I am having a bad build day with the following:
15735 groldan /**
16262 groldan * Overrides to return {@link WMS#getJPEGNativeAcceleration()} if the requested response format
16262 groldan * is image/jpeg, otherwise if it’s set to false and native JAI is available JPEGMapResponse
16262 groldan * will assume the WMS setting and create repeated tiles because it will not get a
16262 groldan * BufferedImage.
16262 groldan *
16262 groldan * @see org.geowebcache.layer.MetaTile#nativeAccelAvailable()
16262 groldan */
16262 groldan @Override
16262 groldan protected boolean nativeAccelAvailable() {
16262 groldan boolean useNativeAccel = super.nativeAccelAvailable();
16262 groldan if (useNativeAccel && ImageMime.jpeg.equals(responseFormat)) {
16262 groldan useNativeAccel = WMS.get().getJPEGNativeAcceleration();
16262 groldan }
16262 groldan return useNativeAccel;
16262 groldan }
The @Override is failing with:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gwc: Compilation failure: Compilation failure:
[ERROR] /Users/jody/java/geoserver/trunk/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerMetaTile.java:[60,38] cannot find symbol
[ERROR] symbol : method nativeAccelAvailable()
[ERROR] location: class org.geowebcache.layer.MetaTile
[ERROR] /Users/jody/java/geoserver/trunk/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerMetaTile.java:[58,4] method does not override or implement a method from a supertype
[ERROR] → [Help 1]
What is the correct procedure to fix this? I assume the GWC jars need to be redeployed?
Jody Garnett
Bah; I think I got it figured. Using Maven 3 - and since this is a snapshot I needed to remove ~/.m2/org/geowebcache
Please move along nothing to see here…
Jody Garnett
15735 groldan /**
16262 groldan *
16262 groldan */
16262 groldan }
16262 groldan }
[ERROR] → [Help 1]
Jody Garnett
